Recording freeze after sometime in dm800hd se
  • uu161
    • May 2012
    • 372
    #16
    those who had problem to mount path media/hdd
    got this from other fourm
    may try this
    add line to /etc/fstab ... example:
     UUID=9e8797fd-76d0-4884-8edg-50bd8c3189e8 /media/hdd auto defaults 0 0
     UUID you get , when you run in telnet command: blkid
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
    • gsml1980
      • Jan 2013
      • 9
      #17
      Originally posted by uu161
      recording freeze mine had fixed
      internal hdd installed
      am now using Cnigma-OpenPli 2.1-dm800se-ssl84b.nfi
      before also have a problem on the above images.
      this is what i done
      1) flash BlackHole-1-7-0-dm800se-ramiMAHER
      2) initialize hdd and mount ( which i find blackhole initiallze the old ver much stable ) for mount /media/hdd
      after tested path all working. BlackHole-1-7-0 don't come with cams if u want install ur own and setting and key etc
      3) now reflash to Cnigma-OpenPli 2.1-dm800se-ssl84b.nfi
      4) it will automount without need to do any thing on initialize hdd and mount again path will be all set and u are ready to go
      this work for me
      don't blame me if it do not work for you.
      1 more thing i had done update the TS Panel 6.1
      the above tested
      800se 210 sim
      front processor ver 1.0
      2.5 hdd 500gb 5400rpm
      time recording
      full day recording
      Can I ask, so is the problem with the time sync or with the formatting/mounting of the HDD? I'm having the same problem. Freeze when record HD channel
      • ypvs125
        • Dec 2010
        • 506
        #18
        Mobo problem.
        • uu161
          • May 2012
          • 372
          #19
          time sync is another issue should be happen on front processor version 3
          nothing to do with recording freeze
          front processor 1 mobo depend on luck i think
          for lesser freeze use previous version of cnigma openpli 2.1 happen once in the blue moon for me
          newer cnigma openpli i got problem on network mount when start recording for awhile it freeze
          but i can't confrim what wrong yet
          and my 12 bay Nas need to send for RMA
          when it back i will test again
          • gsml1980
            • Jan 2013
            • 9
            #20
            Originally posted by ypvs125
            Mobo problem.
            Hi, mind elaborating about the mobo prob? Mine is frontproc ver1 running cnigma2. Mobo is d6 I think, has the mini flashup button behind.
            Recording to usb or internal hdd, not NAS
            • ypvs125
              • Dec 2010
              • 506
              #21
              Any link for the image?
              • uu161
                • May 2012
                • 372
                #22
                the image done by you
                now am using the one before the latest cnigma openpli image that u posted not long ago
                i didn't upload yet and my backup are with magic file
                i might mistaken which older ver
                maybe is this Cnigma-OpenPli 2.1-dm800se-ssl84b.nfi
                i can't remmeber well check pics
                once u saw boot logo i guess u know which one
                • gsml1980
                  • Jan 2013
                  • 9
                  #23
                  This is the exact same one that I have. My set just keeps freezing when recording. Cant even record a complete show. Help!
                  • uu161
                    • May 2012
                    • 372
                    #24
                    Maybe try flash other image and test which one work for you. Sometime a few reflash would help mean time u play around first when I free I will do a backup and let u test see it work for you.
                    • pekakbadak15
                      • Mar 2012
                      • 103
                      #25
                      I thought only front processor 3 having this recording problem.
                      Mine only gets stuck when recording hd channels even though the time is syncronize correctly via dvbtime plugin.
                      • gsml1980
                        • Jan 2013
                        • 9
                        #26
                        Hi, tested last night, recorded for over 8 hrs SD channel FTA no freezing.
                        Now testing infinite recording on SD non-FTA channel.
                        • gsml1980
                          • Jan 2013
                          • 9
                          #27
                          And yes, hanging appears to happen only during HD recordings. Could this be a hardware problem? I feel like its a software issue...
                          Recording SD non-FTA hangs as well.
                          • gsml1980
                            • Jan 2013
                            • 9
                            #28
                            Is the problem the softcam? I dun know how to install an alternative to test. Anyone can help?
                            • ypvs125
                              • Dec 2010
                              • 506
                              #29
                              I don't think softcam is the issue but no harm trying as these clone boxes may behave differently or u could try out with a different image.
                              • stanleywoon
                                • Oct 2012
                                • 16
                                #30
                                Hi, my 800se also freeze when streaming via m3u after sometimes , if watch using HDMI it does not happened. If doing recording to network mount drive it will freeze also, image is openpli 2.1, anyone have same issue ?
