New Images for SG use only
  • terrysg
    • 30
    #421
    That is my guess too...
    msg the supplier he told me maybe too and ask me to resolder see if can anot.. sigh~
    big operation work!
    Originally posted by Bomchacha
    Likely to be a faulty HDMI port of your box
    • ypvs125
      • Dec 2010
      • 506
      #422
      Dm800se newnigma v3.3.1 image with latest channels updated. Ftp yr own key files and do a restart softcam. In these bouquet, Ch226-228<=>135500mhz, ch229-231<=>129000mhz and ch232-233<=>150000mhz.
      SG-Newnigma V3.3.1-dm800se-SSL-84a.nfi
      • digitalscv
        • May 2012
        • 16
        #423
        sorry wat do u mean in this bouquet? still need to edit some of the things manually?
        • goodlands
          • Mar 2012
          • 52
          #424
          CCCam inside, guru?
          • digi16
            • Jan 2013
            • 13
            #425
            Master ypvs,
            Possible to crate one for DM800HD?
            • digitalscv
              • May 2012
              • 16
              #426
              thanks. can see the channels already...on off got some distorted images but still ok....download the image, upgrade then ftp keys. DONE!
              • terrysg
                • 30
                #427
                This is my first time using 800se.. any master can advice me how to backup my images to *.nfi?
                I cant do it like 500 backup style... =(
                • ypvs125
                  • Dec 2010
                  • 506
                  #428
                  Originally posted by digi16
                  Master ypvs,
                  Here is the link. Ftp yr own key files and restart softcam.
                  SG-Newnigma V3.3.1-dm800-SSL-84a.nfi
                  • pekakbadak15
                    • Mar 2012
                    • 103
                    #429
                    I am using dflash plugin for the backup.
                    • pirsquared8
                      • Feb 2013
                      • 114
                      #430
                      Same here too. down load it via tspanel -> addons -> sim2addons
                      • madjack
                        • Apr 2012
                        • 28
                        #431
                        You need a thumbdrive to connect to usb. Go to TS PANEL, look DEVICE MANAGER , press RED button to DISMOUNT & RED button again to MOUNT. Select No.1 as MAIN HDD & exit. Then you need to go to TS PANEL again to ADDON, under TUNISAT look for DFLASH PLUGIN. Once you manage to install Dflash, go to SYSTEM - SETUP - FLASHING & BACKUP, follow prompt & you are good to go. Wait for around 5 to 8 min. Once completed, you have to ftp the NFI FILE from your USB to PC to backup your FULL IMAGE.
                        Credit:ZM00601
                        • sneezereer
                          • Feb 2013
                          • 11
                          #432
                          Credit:ZM00601
                          The tricky-part is also to manually type (with the remote-control) the the backup path to: /media/usb//
                          during the DFLASH backup configuring setup.
                          I placed my USB-thumb on the upper-usb-slot on my DM800.
                          The double // is crucial, missed these and you will get backup failure error! Realised these after umpteen trials.
                          • IjalAdique
                            • Aug 2013
                            Hi all, in my rush to flash to the latest firmware on my DM800HD PVR, I did not save down the scce and keys..now only FTA channels are watchable.
                            Any masters can help me.. Plss
                            • iise7en
                              • 9
                              #434
                              SOLVED! Deleted!
                              • digi16
                                • Jan 2013
                                • 13
                                #435
                                Just few posts up ypvs posted an image with boutiques. That is all you need.
