SGSH E1 Online Bouquet plugin
  • ypvs125
    • Dec 2010
    • 506
    #91
    Originally posted by zaki1462
    So i just need to flash one of these images and ftp my current keys and scce folder and update thru the plug in. Is that rite bro?
    Just ftp yr keys and scce folder and restart softcam and u r ready to go. The image already comes with updated channels and picons. In the channel bouquet, i have removed the unnecessary channels like ch100,200,231,232 etc.
    If u run the plugin, it will fetch the online bouquet managed by dbtraitor. Yesterday, i tested and found channels 809 is not yet included.
    • ypvs125
      • Dec 2010
      • 506
      #92
      Originally posted by DBTraitor
      yup, will update over the weekend
      Bro, why not include the picons as well like the e2 bouquet plugin? U can put the picon folder in var/tuxbox/config/enigma before compressing it and add a line in the script to delete old picon before getting the latest ones.
      • prashn80
        • Dec 2012
        • 25
        #93
        Just tested the E1 plugin on DM-500C...works like a charm and all channels are in the correct order. Excellent job, masters..
        • zaki1462
          • 9
          #94
          Thks Bro...just did what you told. Everything in perfect order. And thks to Bro Dbtraitor for maintaining the plug-in. You guys rockkk...
          • DBTraitor
            • Feb 2011
            • 616
            #95
            Just updated the bouquet and service
            I dump in the picon folder as well, not sure if it will update picon as well
            I didn't edit the script as I am no expert in script writing and I dont understand at all
            Pls try the e1 plugin and feedback if all is working and in order?
            A wise man learn more from a foolish question than a fool can learn more from a wise answer.
            • uu161
              • May 2012
              • 372
              #96
              ok added remove script for picon
              enjoy
              pls take note not yet test
              but i guess shouldn't be any problem.
              if you like the post use the Like button located bottom right corner of each post
              if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
              • mike7168
                • Dec 2010
                #97
                Dm500c - Service could not be decrambled
                Bro, after updates. this erroe still exist. Please help PM me. Thanks
                • ypvs125
                  • Dec 2010
                  • 506
                  #98
                  I have reupload the dm500c and dm800hd image to include this online bouquet plugin with latest channels and picons and can be downloaded from this thread.
                  post #36-dm500c
                  post #39-dm800hd
                  • Koonz
                    • Dec 2012
                    • 63
                    #99
                    I have not come across this error message on a dreambox 500c (with or without keys/scce)
                    'Service could not be descrambled''
                    Maybe some senior can enlighten this part...
                    Ok, I think I google and found out that only Enigma images gave this error......and the propose solution is
                    Goto SETUP > EXPERT SETUP > HIDE ERROR WINDOWS and make sure it's ticked. No more errors now but it takes about 2 seconds before the picture comes on the screen.
                    • ASTROBOX
                      • 163
                      #100
                      Good that u managed to resolved minor issue on yourself
                      FYI that's what i normally do when i need to resolved issue by myself not to depend on others then post if i really cannot get the answer
                      Well done
                      • forbezy2010
                        • Jul 2010
                        • 12
                        #101
                        rite peeps im stuglling here.
                        i have my own dreambox 500c on c/s
                        i would like to upload my channel lists to my site
                        and adapt my update file into the script for my
                        friends to get the new channels via plugin wen i add new
                        ones .
                        any one help me at all email help or blackberry messenger help ?
                        pleaseeeee
                        • uu161
                          • May 2012
                          • 372
                          #102
                          ones .
                          pleaseeeee
                          i don't really see any point if using for sg
                          just use the ready make is good enough for sg use.
                          • forbezy2010
                            • Jul 2010
                            • 12
                            #103
                            im using a dreambox 500c on plijade image
                            • ypvs125
                              • Dec 2010
                              • 506
                              #104
                              I think the plugin should run fine on any image although i have only tested it on open pli image. If u r maintaining the channels bouquet for yr friend, firstly, u got to create yr own server. Next, convert yr bouquet folder to tar.gz and upload it to yr server. Test by downloading the folder and proceed to ftp the script to yr box once u are successful in downloading the folder. U can use the script on this thread but do not forget to change the url to point it to yr server and take note of the folder name too.
                              • reddy
                                • 37
                                #105
                                Deleted. Wrong post.
