FY800HD
  • th3keeper
    • Aug 2013
    • 5
    #316
    Originally posted by shidevil
    If you have explore. U wouldn't have miss out any. It's at the channel list setting. Just go and look at it.
    Ok. Shall take a look there then.
    • Andykoh198
      • Feb 2011
      • 21
      #317
      My post got deleted =(
      • PremierD
        TAMINATOR
        • Jun 2009
        • 13237
        #318
        Why ? .....................
        • Andykoh198
          • Feb 2011
          • 21
          #319
          Maybe posted something mods dun think is suitable.. was replying to a bro gettinf poor reception. Getting black rf cable and shorter ones will helo. Also was asking about n3 technology. If it requires card when it " officially " launches or a fw upgrade would help?
          • rowdyruffbrick
            • Mar 2013
            • 7
            #320
            hey guys anyone can help? my FYHD-800cii quality seems to have dropped after i changed some frequency for the BPL. any idea how to fix this? images used to be sharper
            • novaol
              • Dec 2012
              • 110
              #321
              Just roll back your steps and change back the settings which you had made, else the possible way was to reset back to defaults and starts all over again. Hope that helps.
              • novaol
                • Dec 2012
                • 110
                #322
                I noticed that for DreamBox there is a team who setup all the channels nicely to it's group. Does FY team has a similar way with updates so that I can update the box for a friend who uses FY800HD! Appreciate your help on this. Cheers
                • Andykoh198
                  • Feb 2011
                  • 21
                  #323
                  Try to use the black antenna cable. Gives u better signal. White cable is rubbish
                  • pirsquared8
                    • Feb 2013
                    • 114
                    #324
                    FY boxes cannot be compared to DM clones as the later OS is a proper Linux OS with greater flexibility. So for the case of yr friend, i would suggest that you
                    1. delete all the stored channels
                    2. then do a NIT channel search (of course you need to have set the various 6090 6875 frequency range etc.. to automatically search)
                    quess you do not need any channel sorting as after the NIT search, you can use the 3 fiqure channel selection that is similar to the Green fat Pipe guys.
                    • jenovauh
                      • Sep 2013
                      Originally posted by Menifestozz
                      Hi guys im new here and read many post regarding FY Hd however I still unable to receive epl chanels. I waited for 30secs to 5min still no signal. I believe I got all other chanels except EPL.
                      My model as follows:
                      Model: HD-FTA-AVS+DVB-C
                      SW Version: HDC800 V1.4 TNDT
                      FW Version: HDC800 V2.0
                      SW VersionTime: 2012-8-3
                      Please advice. Do I need to update the software and firmware? I cant seems to update the firmware using FY. At and .Bin help pls.
                      When I select .bin to ref lash my firmware, the screen flickers and back to channel 101. Unable to proceed to updating screen.
                      Hi Menifestozz, your firmware version is same as mine, I just flash mine from this url and it worked. So dont loose hope and good luck.
                      • khairulalonso
                        • Sep 2013
                        Anyone can help? my box can't detect fy.ap
                        i accidentally updated my FYHD HDC800
                        anyways i can unbrick or downgrade my firmware? pls help! TQ
                        it can't even detect any channels.
                        • justbear
                          • Aug 2013
                          • 10
                          #327
                          Delete
                          10chzrs
                          • croc
                            • Jul 2012
                            • 70
                            #328
                            any firmware update for this machine?
                            some how manage to power up after 2 mths shut down...
                            just want to use till d day cum
                            • plasterer
                              • 1631
                              #329
                              You could try the URL in jenovauhs post 3 above this one He seems to have had a sim prob and got his going with the firmware from that link,
                              Nothing to loose really .................Paul
                              If your Happy with the Help push the Thanx button
                              PAUL
                              • croc
                                • Jul 2012
                                • 70
                                #330
                                where is the link?
