FY800HD
  • croc
    • Jul 2012
    • 70
    #121
    those with white FYHD.....are you able to get any BXL channels?
    with firmware 071713 ? or?
    • Pokemon999
      • Nov 2010
      • 35
      #122
      I just upgraded my white FYHD to the one posted by jastro on page 7. Everything works fine now. CH229-231. Excellent support from by jastro. Thank you.
      • riozis05
        • Jul 2013
        Originally posted by jatrophaseed
        Master SGDVB, FY site it is still there, they juz lazy to search.
        I no more support FY boxes.
        Thanks Mmouse, I try not 2b conservative but some PMs really make my day.
        However,this my last posting of update for FYHD800C and TNHD888 (both can use),juz to show my sincerity to some good friendly Brothers' need.
        Thank you!
        • ronny1
          • Aug 2013
          • 25
          #124
          can anyone manage to scan 135.5mhz on FYHD?
          my black box return no value leh.
          128.5mhz gives me 129, 130, 131.
          149.5mhz it says 8 tv found, but it didnt show any more epl channel for me
          jathro bro any advise?
          • ypvs125
            • Dec 2010
            • 506
            #125
            Have u try with 136 and 150?
            • nelsonhtb
              • 44
              #126
              Can rcv no problem.
              Did you btw change SR to 6090?
              Try again should work if you used latest fw.
              Sent from my Nexus S using Tapatalk 2
              • ronny1
                • Aug 2013
                • 25
                #127
                ya i try bro. i try 149.1 all the way to 149.9 and 150
                also try 135.1 all the way to 135.9 and 136
                Originally posted by nelsonhtb
                Can rcv no problem.
                Yes brother i use 6090 all nothing sia. why man
                • mq2012
                  • Dec 2012
                  • 15
                  #128
                  me too with the latest few, fyhd can only tuned to 229,230 and 231. for DM800 with the updated E2 SGSH online bouquets updater plugin for sg from master uu161 can get all 8 channels.
                  • ultrakiasu
                    • 128
                    #129
                    Once you upgraded the firmware, don't scan manually.
                    Do a factory reset, and upon the language setting page, just do a blind full scan.. and wait..
                    (press ok ok ok ok.. all the way.. no need key in anything...)
                    It worked for me...
                    • mq2012
                      • Dec 2012
                      • 15
                      #130
                      Thanks for the info, anyway follow your method still don't work for me only the same 3 channels.
                      • SGDVB
                        • 210
                        #131
                        This is the disadvantage with the FYHD, MVHD, TNHD or watever XXHD they call them b'cos the channel were found as data instead of tv profile when scan.
                        For dreambox, the brother here who provide the bouquet or updates used dreamboxedit to change it from data to tv.
                        There are many software to support dreambox unlike those oem boxes will have to wait for official firmware updates from the manufacturer.
                        Those who have tried using dreamboxedit or dreamup will understand wat I'm trying to say here.
                        I'm oso not saying the dreambox is good or powerful or trying to put other boxes down. Juz my 2 cents worth. Dreambox recently oso have many problem itself due to component discontinued therefore the maker are using china oem part to substitute resulting all the problem like image drop or weaker signal.
                        Hope my comments does not offend any trader here.
                        • jatrophaseed
                          • May 2010
                          • 589
                          #132
                          Something b4 I go on leave.
                          What ever box need from now pls choose those which full digital tuners, yhose Bros cant get chn r those tuner with the Fconnect and TV connecter further apart than 10mm, thats bcos those r the coil tuner with low sensitivity for extreme low or high freq.
                          I hv posted the type of tuners to look for, pls refer back to many mths ago on jpg of tuners.
                          Juz my finding, those boxes with Full digi tuner can recvd all 8chn, no proble, including FY boxes. Those not digi tuner, most hv difficulties. No way around xcept by a booster or change box. Last nite all 8 were tested and runs very smoothly, ie, all 8chns r now fully operational, but I still believe they will still increase signal strenght some days later as more subscriber registered.
                          • fabz87
                            • Jul 2013
                            • 9
                            #133
                            Yeap. Same for me. Any gurus can help?
                            • croc
                              • Jul 2012
                              • 70
                              #134
                              FYHD Picture - More Detailed Picture about Latest! tnHDC 888 is Singapore HD800C best white box FYHD800C Set Top Box Better than FYHD FYHD800C Picture in Set-top Boxes from BESTBOX
                              r u guys talking this box? cos mine is this
                              • ultrakiasu
                                • 128
                                #135
                                Obviously you guys not aware there is a even latest newer model from "Tonnow" model tnHDC-999
                                But owned both models and tested, there is a serious flaw which may be a problem soon.
                                May avoid getting the model if that important function is not present.
                                I will be testing the MV HD series next week..
