CANT CONNECT DREAM BOX TO FLASH FXP OR SIMPLE FTP APP FOR DREAMBOX
  • boothuk
    • 251
    #46
    Did you follow the settings as above, but change the IP on your laptop TCP/IP settings to 10.0.0.1 instead of 10.0.0.2. I don't see why your firewall would autoblock the FTP client or port 21/80.
    Try the setting's here, but like as said, in the picture, I put the wrong IP address in (I did it quickly in work to show you the correct screen). Change the IP address to 10.0.0.1 and all the other settings as in that post.
    • staggers
      • Apr 2009
      • 149
      #47
      tried all those settings m8 no good dont know what to try now tried fxp filezilla and dreambox control centre and tried ping from those setting no packets out of 4
      • boothuk
        • 251
        #48
        I thought you pinged 10.0.0.1 successfully?
        • staggers
          • Apr 2009
          • 149
          #49
          ye did on friday, today no joy, i am doing everything right,theres just something stopping me from connecting its really annoying me ,is there anything else i can try?would any settings in router affect this?
          • boothuk
            • 251
            #50
            Your connecting through an RJ45 cable, aren't you? Your router has nothing to do with it. Although you could try disabling your wireless card on your laptop....
            • dehowletts
              • 35
              #51
              as far as dbox is concerned i'm a newbie but networking wise i'm not, so thought i'd but in with 1 or 2 things here hope u don't mind? (typical woman eh?!)
              are u now trying through router or xover?
              if using xover can u 'see' the dbox an your lan (i use a xover to server set up in work for demo's of software and protocol's the same)
              if connecting through router there's quite a few things i'd try:
              1. check the port on router's not dead (if more than 1 free use a different 1)
              2.check you haven't locked down on no of connections allowed through router (i only allow 10 through mone for extra security layer)
              3. have you checked ALL your ipconfig just in case anything wierd ging on? (start run cmd then type "ipconfig/all")
              4. reset router and go from the top setting n/w back up that way it'll force u to check all settings
              dunno if this helps? Claire
              • boothuk
                • 251
                #52
                Why don't you post a screen shot of your TCP/IP settings and a photo of your DB connection settings. There must be something your missing if you could ping the other day? Maybe people suggesting different IP's has confused the matter...
                • staggers
                  • Apr 2009
                  • 149
                  #53
                  hi booth cheers m8 for trying
                  heres my settings
                  DREAMBOX IP 10.0.0.2 DHCP UNCHECKED
                  NETMASK 255.255.255.0
                  TYPE LAN
                  NAMESERVER 10.0.0.1 ENABLE NETWORK CHECKED
                  GATEWAY 10.0.0.1 PORT 80
                  ON LAPTOP INTERNET PROTOCOL VERSION 4 TCP/IPV4
                  IP 10.0.0.1
                  SM 255.255.255.0
                  DEFAULT GATEWAY 10.0.0.2
                  I HAVE NOTICED ON VISTA THERE IS ALSO INTERNET PROTOCOL VERSION 6 TCP/ IPV6 OPTIONS
                  STATUS ON LAN CONNECTION: LIMITED
                  tried to ping these settings get 100% loss hope this makes sense to you cheers again for your help m8 stags
                  • boothuk
                    • 251
                    #54
                    Default should be 10.0.0.1 on pc
                    • staggers
                      • Apr 2009
                      • 149
                      #55
                      hi booth that was a typing error i had pc default 10.0.0.1 stiil 100% loss when i try to ping these setting,does that ipv 6 mean anyting to yo as i said in last post when i go to lan propertys it has 2 internet protocol versions 4 which looks like your one on xp and version 6which is a bit different optons ipv 6 address ,subnet prefix length allows 3 digits,and default gateway ,just thought i would mention evrything i can think of, and you think nothing to do with router? tx again m8 stags
                      • MetalKettle
                        V.I.P.P.T. Member
                        • 797
                        #56
                        You dont need to touch ipv 6.
                        Im confused.... are you connecting via crossover or router?
                        XBMC/KODI Developer
                        • staggers
                          • Apr 2009
                          • 149
                          #57
                          crossover cable m8
                          • MetalKettle
                            V.I.P.P.T. Member
                            • 797
                            #58
                            heres my settings
                            TYPE LAN
                            IP 10.0.0.1
                            SM 255.255.255.0
                            Try deleteing the Gateway from the laptop settings
                            XBMC/KODI Developer
                            • psats
                              • 823
                              #59
                              crossover cable m8
                              you need to set the box ip in the same range as your network card on pc
                              pc. 192.168.0.10
                              dream. 192.168.0.8
                              • staggers
                                • Apr 2009
                                • 149
                                #60
                                tried deleting same outcome conection failed
