Lastest SG Updated Channels for the upcoming B****P****L?
  • ronny1
    • Aug 2013
    • 25
    #16
    Originally posted by hockheng
    do manual search for the MV box
    226,227 & 228 frequency 135.5hz and 6090kbps..
    mine is FYHD the black box. i did 135.5 and 6090 nothing comes up :/
    • Cyclist23
      • Jul 2013
      #17
      FYHD black box can only search with 3 digit hence cannot do a 135.5 right? How you manage to key in a 0.5?
      • ronny1
        • Aug 2013
        • 25
        #18
        the firmware updated by jathro bro can input .5
        • jack_diniro
          • 23
          #19
          Did you managed to scan for the new channels?
          • fabz87
            • Jul 2013
            • 9
            #20
            bro i scan 135.5 with 6090 shows nothing, 149.5 shows 8 channel but no epl.
            128.5 gives me 129,130,131.
            any idea?
            I have the exact same problem bro. Any gurus can help?
            • croc
              • Jul 2012
              • 70
              #21
              FYHD Picture - More Detailed Picture about Latest! tnHDC 888 is Singapore HD800C best white box FYHD800C Set Top Box Better than FYHD FYHD800C Picture in Set-top Boxes from BESTBOX
              can the firmware use for this?
              • jnashville
                • Apr 2012
                • 70
                #22
                for me...i used the image given by yvs... even though the image has the bpl channels..i cant watch it. but after i use back my old image, i just upload the new bouquet list with the bpl channels, i am able to watch 2 channels, ch 232 and 233, which are mio stadium 107 and 108. So sometimes maybe u should try different images to test around.
                • ypvs125
                  • Dec 2010
                  • 506
                  #23
                  The newer channels with sr6090 have unfix frequency so u got to scan manually and see which one is able to watch on yr dm800 and edit accordingly to yr existing bouquet. Eg. 149500mhz, u can scan for freq 149mhz & 150mhz and u will be able to view the channels on yr box. If u get tune failed, it means it is not in the right frequency.
                  • jnashville
                    • Apr 2012
                    • 70
                    #24
                    icic. but i notice for dm800hd, i cant input 149.5, or 128.5 etc. I only can put 3 digits without decimal place. I go in dreamboxedit also notice 3 digits for the freq of that channels.
                    • mq2012
                      • Dec 2012
                      • 15
                      #25
                      you use this version can. DreamBoxEdit-YASSINOV-EDition-V4.0.3.3
                      • ypvs125
                        • Dec 2010
                        • 506
                        #26
                        If u r doing auto scan with cables.xml, it will scan the frequency that u input in cables.xml but in doing manual scan either u scan 149 or 150. For dm800 and dm800se, cables.xml is not necessary, it will still find all sh channels when doing auto scan.
                        • jnashville
                          • Apr 2012
                          • 70
                          #27
                          oh dont know wat u mean by auto scan with cables.xml...noobie here. =x
                          the way i scan is just go to menu, then system den under service searching...choose manual scan... change freq to 129 and SR 6090 and scan. I nv do auto scan cuz i tried once...but always say tuner fail at blabla mhz...so its either i use astrobox bouquets and upload to my box through dbedit or manual scan.
                          • jnashville
                            • Apr 2012
                            • 70
                            #28
                            okay i have installed.
                            i opened the E2 bouquet 6 August given by ypvs125 and i notice the frequency of the bpl channels are 150000, 129000 etc... so i just edit in dreamboxedit from 129000 to 129500 and do for the rest. Is that it?
                            er i notice i try to edit the frequency in dbedit but the frequency option is greyed out. So cannot edit the frequency..
                            Sorry novice here.
                            • wizzz8wizzz
                              • Apr 2012
                              • 8
                              #29
                              Think I have to get a DM800 for B*P*L. Can anyone direct me to a reliable source for DM800HD PVR or DM800HD SE. TIA.
                              • nottidude69
                                • May 2013
                                • 6
                                #30
                                Bro, check out dreamTVbox.net - Dreamtvbox.net - Digital Receivers for Singapore....
                                Cheers!
                                NottiDude
