Lastest SG Updated Channels for the upcoming B****P****L?
  • DBTraitor
    • Feb 2011
    • 616
    #61
    dont waste money hard earn bro..... hahaha
    Follow the instructions on manual search
    1) Manual Search for 135500 symb rate 6090
    2) Manual Search for 149500 symb rate 6090
    Nvm about whether the new channels are in order or not. As long you know that new channels are right at the end of your list. Rearranging of channels can learn later. One step at a time, dont rush. You will get confused. Read more first before doing anything
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • DBTraitor
      • Feb 2011
      • 616
      #62
      Originally posted by jnashville
      so for those boxes u mention, if there are new channels, only way is to do a manual or auto scan right?
      Yes, an auto search will do. Hopefully your firmware is capable of rearranging to the correct order
      • zevth
        • Jul 2013
        • 11
        #63
        Just a quick question, is your chn227 showing old matches or the same thank you for subscribing message as the other channels? On the multiview it looks like 102(227) should be showing an old match, but the actual channel is just showing the thank you for subscribing screen.
        • Lau Hokkien
          • Feb 2012
          • 5
          #64
          DB Traitor,
          For my DM800HD-PVR, can I use auto instead of manual scan?
          • Koonz
            • Dec 2012
            • 63
            #65
            if u use auto scan, your channels will be all in a mess unless you don't mind.
            There is a thread on updating of channels.
            • Lau Hokkien
              • Feb 2012
              • 5
              #66
              Hi,
              I did a manual tune at 136 symb (6090) I couldn't enter 135.5 on the DM800HD so I just try the nearest decimal point.
              Managed to locate m-i-o stadium (8 channel) but it's all pixelated. Any thoughts?
              • edlimym
                • Feb 2012
                • 29
                #67
                Originally posted by Lau Hokkien
                Hi,
                did you plug your box directly to the wall outlet and standalone? i did that and those channels ok. chn 232 & 233 is ok all the while.
                • Bomchacha
                  • Feb 2013
                  • 117
                  #68
                  Hi,
                  if 136 cannot, scan for 135
                  • ijalsp
                    • Feb 2013
                    • 11
                    #69
                    Hi,
                    Same here... located but pixelated (more like only top 1/8 of screen can be seen) even used the 2 sets provided in this thread. oh you can edit the frequency for 135500 in Dbedit (one of the versions mentioned in this thread) did that then pushed the files back to box. But unfortunately mine still pixelated. So far managed to get last two channels only. The rest including multi view still the same. Will try other frequency tonight. Saw one of the post in another thread mentioned 134500. Any other tips?
                    Sent from my GT-I9300 using Tapatalk 2
                    • ultrakiasu
                      • 128
                      #70
                      The same issue encountered when I used the tuner module from a newly bought 800HDse, once I changed the module (without reflashing), the channel can be seen full-screen without distortion.
                      • justbear
                        • Aug 2013
                        • 10
                        #71
                        mind i ask, is there a thread regarding the tv modules? i believe they are soldered onto the board and how to make sure we can the correct part for the module
                        • ijalsp
                          • Feb 2013
                          • 11
                          #72
                          Do you mind sharing what should be done to change the tuner module?
                          • Lau Hokkien
                            • Feb 2012
                            • 5
                            #73
                            some updates here.
                            thanks to edlimym suggestions, I'm able to receive good signal
                            One thing, manual scan shown 8 channels found but I'm only able to see 3 channels. Reckon the rest are not up yet?
                            I can see the following channel,
                            M Stad_ _ _Multiview 101
                            M Stad_ _ _102
                            M Stad_ _ _103
                            I will learn how to use the dreamboxedit asap. As of now, I'm scanning it manually.
                            Many thanks for those for help me along. Appreciate!
                            • ypvs125
                              • Dec 2010
                              • 506
                              #74
                              The 2 bouquet provided is just a guide line. So u need to explain what are the outcome when u push the bouquet to yr box eg. Ch226-ch228 pixelated and ch229-232 is ok or vice versa and then u begin to tackle to the channels which having problems and leaving the ok ones alone.
                              • ijalsp
                                • Feb 2013
                                • 11
                                #75
                                Yup2... understood the 2 sets of bouquets were just guides. Will do it all tonight. Trial and error with all the frequencies and update.
