Lastest SG Updated Channels for the upcoming B****P****L?
  • ypvs125
    • Dec 2010
    • 506
    #46
    As newer channels with sr6090 reside in 0.5mhz region, it maybe difficult for some to manually scan it as we are not able to input eg. 129.5mhz in the scan frequency. For some tuners, u can get the channels if u input 129mhz or 130mhz but some will only receive it if it is 129500mhz. Best is to do an auto scan for yr own box since we are using different tuner to see yr tuner is capable of picking which frequency and edit yourself using dreamboxedit and i don't see a need to change for the tuner as most of the channels are viewable. I have include below 2 sets of bouquet which have 2 different sets of frequency on sr6090 and could try on yr box to see the difference.
    E2 Bouquet 12AUG13.zip
    • uu161
      • May 2012
      • 372
      #47
      Originally posted by ultrakiasu
      I got 3 tuner modules extracted from brand new DM800HDse clones, problematic dealing with those half-frequencies, and they either can't received those 8 channel or just 3 channels.
      But when I swapped with my spare brand new tuners, without meddle with any setting, the new tuners able to receive those channels with video and audio, no scrambled image.
      I conclude, yes, tuner quality play a big part too.
      what to do QC of clone tuner is like that
      it will fixed by which freq are use
      before confrim tuner fault try auto scan if auto didn't get that 6 channel then problem on tuner itself
      different brand of tuner do make different by 0.5 + -
      if you like the post use the Like button located bottom right corner of each post
      if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
      • jnashville
        • Apr 2012
        • 70
        #48
        one of the set i have i used freq 135000 and 136000..both pixelated. so i use 135500 and it solved the problem. but for other sets, i used 136000 and it worked fine. Guess some tuners are more sensitive.
        • ypvs125
          • Dec 2010
          • 506
          #49
          Yes it all depend on yr tuner on yr box and what master uu161, it is better u do an auto scan to determine which frequency is best for yr box and the bouquet provided by me is just a guide and not to be follow exactly.
          • micromouse
            • 162
            #50
            SSSSSSSSSSSSSSSSSSSSSSSS
            • gnnbccb
              • 10
              #51
              Dear Sir,
              I would like to inform you that your SET 1 works for my si bei old DM800HD.
              Thank you SIR!
              • andies
                • Mar 2013
                hi thanks so much for the updated bouquets YPVS125...
                Can I ask whether it's possible to enter 0.5mhz in DBEDIT?
                they only show three digits in the frequency part..
                thanks!
                • Puddie
                  • 33
                  #53
                  Wah for some reason, I just can't get the download to start! The captcha keeps refreshing after I enter the words I see. Bloody annoying. Don't know what can be wrong...
                  • bandwidthspeed
                    • Mar 2010
                    • 21
                    #54
                    I tested shld be not tuner issue I had flash the updated software I saw the channel scrambled even u restart enigma or restart dreambox wont help. The only way is power off the unit and re fix the coaxial cable wait for 1 min and it's work. You can try it
                    • RedRidingHood
                      • Apr 2013
                      • 29
                      #55
                      Which box, someone told me fy, dm800 better?
                      • pekakbadak15
                        • Mar 2012
                        • 103
                        #56
                        Dm800 full control on settings unlike fy box.
                        • beckz
                          • Jun 2013
                          • 9
                          #57
                          For picon, do i need to add picon for those new channels?
                          • DBTraitor
                            • Feb 2011
                            • 616
                            #58
                            Indeed, fully agreed with you.
                            I started with a dreambox, went through a steep learning curve.
                            Those FY boxes are simple plug and play. Meant for those who doesn't want to mess around and just watch the box as it is.
                            I choose dreambox because it is widely supported in many forums. If I face any issue, I know there is an answer for me somewhere.
                            Right now, those FY, Q5, MV boxes, I dont even know how to edit the channels and backup the firmware.
                            There is no program like dreamboxedit to do the job. There is no dreamup etc
                            If these boxes can do ftp, editing channels, xml, I think it will be a great box.
                            A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                            • jnashville
                              • Apr 2012
                              • 70
                              #59
                              so for those boxes u mention, if there are new channels, only way is to do a manual or auto scan right?
                              • Lau Hokkien
                                • Feb 2012
                                • 5
                                #60
                                Hi sg bros,
                                I bought the DM800 HD-PVR from a supplier quite some time ago. I'm a newbie, so it was a plug and play set.
                                With the new B##P##L channel, can I just follow some of the instructions posted by bros here to do an auto scan for the channel?
                                I was thinking of paying the supplier to do it for me, if it's even possible.
