Lastest SG Updated Channels for the upcoming B****P****L?
  • laclah
    • Apr 2013
    • 7
    #91
    Hi all, my DM800HD received all the BPL channels from ch 226 - 233.
    I went into information/service, and go to multiplex,
    freq for 226-228 was fixed at 135500, 229-231 fixed at 128500, 232-233 fixed at 149500
    sym rate at 6090000
    Inversion: Auto
    FEC:None
    When I go to Tuner status
    Freq keeps changing for all channels
    Sym rate at 6090000
    Inversion: On
    FEC: None
    I connect the box in my living room, it plays smoothly, but connected to my room, it was pixelated.
    Is this normal?
    And by the way, I only receive EPG for ch 226-231, there is no EPG for ch 232 & 233
    I have another box which is DM800SE
    sym rate at 6090000
    Inversion: Auto
    FEC:None
    Sym rate at 6090000
    Inversion: Auto
    FEC: Auto
    This DM800SE plays all channels smoothly in living room and bedroom.
    Is the DM800HD and DM800SE settings different? Or It's because different box acts differently?
    • tbanwee77
      • Aug 2013
      Hi I have tried the above method on my set but did not detect any channel for EPL. Any more suggestion? bro
      • ypvs125
        • Dec 2010
        • 506
        #93
        Can u elaborate a little bit more on which method have u tried?
        • goodlands
          • Mar 2012
          • 52
          #94
          For those who can't get clear smooth image, i reckon u r in older estates and/or higher floors.. Don't go for the cheap one-way amplifier aka signal booster.. U'll hv to go for the official moonhub 2-way amplifier... It's much more expensive than normal but worth it even if u plan for n3 someday... D@v j0ne5 in slt basement
          • goodlands
            • Mar 2012
            • 52
            #95
            A thanks from Jedi Master Seed himself makes my day seh, Thanks you Sir
            • ZM00601
              • Jun 2012
              • 39
              #96
              Those Dm800 having freq 135500, 128500 & 149500 , try to clean wall cable point & coaxial cable contact front and back using IPA or Alcohol solution with toothbrush. It could the contact point is moldy. Mine managed to get all the channels smoothly with these simple method...
              • uu161
                • May 2012
                • 372
                #97
                the original one are 1 of the good one but over price
                there is one more ^^ long time no ppl bring in sg
                if you like the post use the Like button located bottom right corner of each post
                if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                • azquestra
                  • Aug 2013
                  Originally posted by mickyyeow
                  Hi brother, to tune for the *** new channel , please follow here ( only apply to DM800 HD)
                  1. press Menu
                  2. Setup
                  3. Service Searching
                  4.Tuner configuration
                  5. It appear Tunner A ........., Enable. Just press enter n go in
                  6.For all scan band US ... change them to yes. ( right arrow will do )
                  7.Only select QAM256 to be Yes
                  8.Change Scan additional SR from 0000 to 6090 ( one will do )
                  9. press ok to save changes
                  10. Exit out to auto scan
                  11.put clear before scan to NO first. before u press OK. If not all your old channel will be lost
                  That all , around 20 -30 new channel can be found
                  Enjoy brother
                  Thanks bro.. Works for me.. U r a lifesaver..
                  Sent from my GT-I9100 using Tapatalk 4 Beta
                  • beckz
                    • Jun 2013
                    • 9
                    #99
                    Mine can't tune to channel 226-228. Keep getting "Tune Fail" msg.
                    Is there something wrong?
                    Tuner: Philips CU1216Mk3 (dvb-c)
                    • Puddie
                      • 33
                      #100
                      Hey bro, thank you SO much for this tip. After trying everything, I finally cleaned the contact points with contact cleaner. Wasn't expecting much at all cos it didn't look dirty at all to me though the cotton bud was a bit blackish. Plus, all my other channels were fine. I screwed the coaxial back in and turned to channel 226 completely expected the same 1/8 fuzzy picture and voila! It was perfect! Signal quality went up from 73% to 93%
                      • moet
                        • Aug 2013
                        Hi Seniors,
                        Im using White FY HDc-800-e for a few mths. So far so good, no complains. However, upon seeing what my friends stb can re-scan to get the beepee L channel, i got curious and google for a bit. With my limited understanding for these stb, im stucked.
                        I cant seems to check what is my version of firmware. The UI for the frequency setting doesnt comes with a decimal. I can see "miostadium" but channel dont exist, i did auto and full scan for many time, i am still unable to get anything.
                        Just need to know if my stb confirm cannot get anything, so i can give up since i dont watch soccer (thou having 1-2 channel during weekend where friends gathered is good), and if miracle may happen, how do i tune the set as currently 223-22x doesnt appear.
                        Sorry for the WOT and pardon me if i did anything or say anything wrong here.
                        Cheers.
                        • beckz
                          • Jun 2013
                          • 9
                          #102
                          I solved mine by doing this too...!!
                          • potatogal
                            • Aug 2013
                            • 5
                            #103
                            Hi all,
                            I'm from SG. I have been reading quite abit. i am planning to buy a clone set but not sure DM800HD or DM800HD SE. Partly my dad is keen to watch the *P L and we are not willing to be held ransom by ST & SH. Is it advisable to cancel your subscription with both after purchasing this set?
                            I am not sure about buying which of the above sets, DM800HD or DM800HD SE and from who:
                            *removed*
                            * very responsive reply me almost instantly always but slightly more expensive
                            *removed*
                            * cheaper but it seems like site is very new
                            Any kind souls have purchased from any of the above and can introduce me a reliable source?
                            Thank you all a million!
                            • ypvs125
                              • Dec 2010
                              • 506
                              #104
                              Originally posted by potatogal
                              Hi all,
                              Singapore DM 800 HD Dreambox with AutoRoll Key
                              Dreamtvbox.net - Digital Receiver Products for Singapore - dreamTVbox.net
                              There is no guarantee on how long we can used this box to view free tv so decision is yours whether to buy it or not.
                              • potatogal
                                • Aug 2013
                                • 5
                                #105
                                thank you for the reply. that is true. but which one should i buy from and which set to buy?
