Been trying to get the Pli image going on another db500, did everything as suggested, checked it and double checked it, still no joy, Any ideas ???
Image : Pli-Jade2-dm500-20090322-6302.img
panic over lads, when I made a new folder to put in var/etc/plimgr/cams I didnt realise it was case sensitive, renamed it to hypercam_1.06 , back out to channels and worked after a min. Many thanks to everyone helping on this, much appreciated lads !!!!!!!!!!!!!!!!!!
I am usining dk 1.1 image, used ftp to transfer files into var/bin and changed attributes to 755.Then pressed blue button and went into tubox commander and selected var/ bin the hypercam 1.06 is visible in this folder highlight it and press ok to execute and save settings then exit out of tubox went to s*y sport 1 and waited for a minute
then changed to s*y sport 2. and bingo back in business.
do a backup of your working image m8 and post it in downloads call dk1.1.irish
Good to see a fix for this. Is anyone experience the same issue as me. I don't get all the channels and when I reboot the Box I lose them all.
Don't really trust me keys anymore after having to reset my box back to factory setting this morning. Can some one point me in the right direction or zip up their Irish NTL keys.
Cheers
Hi ,
Starting my Cam dose work but I am trying to figure out is any one else missing channels like C4 or More4. Is this the case with every one or do I need to update my keys? I did reset box to factory setting messing around with it this morning and not sure if I loaded the correct keys. If some one can access these channels can they let me know and zip me up their keys or let me know where I can download the latest keys...thanks.
Hi ,
it was happening all over m8 .. do a scan an they will be in last scanned in your menu and u will have to edit and move to the folder u want
