800hd scanning for channels
  • dctyper
    • 2539
    cant seem to get any channels on cable??
    anyone know how to manual sca these things
    dc
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
  • Bonesy
    • 655
    simply copy over the cable.xml file from downloads ftp to unit and then you should be able to scan properly.
    Setup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
    • dctyper
      • 2539
      where should i ftp it to?
      • westkill
        • 2378
        what area do you live in
        • dctyper
          • 2539
          brighton, ive just ftp the cable.xml file from my 500c to my 800hd just rebooting now
          • westkill
            • 2378
            the xml might not work in these E2 images
            so
            menu>setup>service searching> manual scan
            there should be a screen look like this
            In the "service Scan" page it says ;
            Tuner - Tuner A DVB-C
            Type of Scan - Single Transponder
            Frequency - 666 < add this
            Inversion - Auto
            Symb Rate - 6887 <add this or 6952
            Modulation - 64-QAM
            FEC - Auto
            Network Scan - Yes
            Clear Before Scan - No
            Only Free Scan - No
            then start scan
            i think this should be right
            • dctyper
              • 2539
              666 didnt work, i randomly put 411 in and its picked up loads????
              • westkill
                • 2378
                how many has it picked up m8
                • dctyper
                  • 2539
                  scan finished 294 services but only fta cleared. the keys are all up to date tho mmmmmmm
                  • westkill
                    • 2378
                    were did you put the keys and scce files
                    • dctyper
                      • 2539
                      in var/keys
                      and var/scce
                      copied direct from my working 500c (running evocamd 2.12 me thinks)
                      • westkill
                        • 2378
                        try this ftp
                        to var/ and delete the keys and scce files
                        then go in to usr/ delete any keys and scce file there as well
                        then ftp back to /usr/ and put your working keys and scce files in there
                        then
                        reboot then, restart what ever cam you using
                        • dctyper
                          • 2539
                          ok, ill give it a shot
                          • dctyper
                            • 2539
                            done that. but still nothing, what other cams do oyu recommend
                            • freck
                              • 1076
                              Have you got "only free" box unticked in the transponder scan option and is "allow service updated " ticked in setup?
                              Just 2 simple thing that can solve a problem like yours.Just adding to what westkill is saying.Sorry for butting in
