Do you have to have a lan lead connected when using dreambox if your using a serial cable ?
NO CA FOUND/FILE TO BIG FIX
Hi, I need some help. I have downloaded 2nd stage_pack for my dm800 hd clone. Okay first up my connection is usb to rs232 to the dreambox and ethernet cable from my modem to my dreambox. Well i think i did everything right and even enforce the flash but i still am having the File to big error. By the way when i hold the silver button and on the power to my dreambox it states error no ca found. Anyway can please help me out here.Comment
.Hi, I need some help. I have downloaded 2nd stage_pack for my dm800 hd clone. Okay first up my connection is usb to rs232 to the dreambox and ethernet cable from my modem to my dreambox. Well i think i did everything right and even enforce the flash but i still am having the File to big error. By the way when i hold the silver button and on the power to my dreambox it states error no ca found. Anyway can please help me out here.
Try and get access to a pc with an RS232 port on it. Some people can flash from a laptop using the usb RS232. I have never been able to manage this. Also try it with a crossover cable if you've been using a staight ethernet.
i have this problem too, only thing is i have null modem cable but when i turn Dm800 it starts uploading flashloader and when its completed,it says "upload completed, waiting for aknolagde", and on dm800s display i get an error msg "Error1: no ca found"
look at www.dm7020.com
I dont get a chance to upload second stage loader to dreambox
what couold I do ?Last edited by Mik018; 22 June, 2010, 13:38.Comment
800HD clone no ac found
Hello Satfriends
I have tried to flash my 800Hd and get the error no ac found I have lookt on this board and find a lot to resolve but I have tried everything but cant get a IP adres and with the Dreamup he load all then get again the same error.
Is there sombody can help me with this
Thanks in Advance
Jopie
SpainComment
Hi buddy, saw your pm, read this thread,
it will definitely solve as i have tried no only once, but few times.
file to big in dreamup
I also had the "file to big" error.
But I found a way around it.
First of you need the null modem cable and the "broken" box need to be connected to the network.
Second use the patched version of Dreamup included in the zip file in romy's post.
Start the patched DreamUp. Make sure network is checked (enabled) and next push the Connect button.
Then power up your dreambox. Upload should start.
After the upload the "No CA found" message should appear. Don't click OK and no need to start enforcer or DM800_repair.
INSTEAD open a browser and go to the ipnumber of the dreambox (it is on the display of the box)
The bootloader webinterface should appear and you can flash the box from there.
It worked for me, I hope it will work for you too.
Good luck,
ScannerComment
My DB was crashed so badly that it corrupted the bootloader (power on the DB and it displays "error" in less than 1 second. I managed to use RS232/LAN method to revive the bootloader and subsequently my entire box.
