TOTAL NOOBS GUIDE TO SETTING UP DM500C
  • rhino
    • 7
    #61
    Originally posted by rhino
    Hi guys, must say the guide is v good and easy to follow, how ever on completion - only FTA chanels are decoding - all other there but just can't see them. In the above post are you saying that the 'Keys' need to be copied to the 'scce' folder as well as the 'nagrae' file??? Thanks in anticipation Anyone.......
    Rhino
    Hi have just downloaded ### Nagrarom Auto Update Fix - 29-11-08 ### and compared it to Nag files from download specified in Noobs Guide, I've spotted a very slight difference in the nags and wondered if i replace the orignal nag files in the scce folder with the ones from ### Nagrarom Auto Update Fix - 29-11-08 ### will this sort out the auto update issue? (have manual updated keys at mo....... )
    Rhino
    • MetalKettle
      V.I.P.P.T. Member
      • 797
      #62
      Rhino
      Spot on mate.... go for it
      No more entering keys (for a while anyway)
      XBMC/KODI Developer
      • Pratai
        • Jun 2009
        Originally posted by shady77
        OK first up, the dk forum is THE place for all dreambox related goodies/help.
        the stickies/guides are easy to follow and comprehensive.
        i know from experience that when you join a new forum, it can be daunting to ask for help not saying that DK is like that, but you know what i mean. anyway i'm rambling. As i stated, the guides are excellent but maybe whats missing is all the info in one file. This isnt a critique BTW
        Anyhoo, ive unashamedely plagiarised devilfish and thommos excellent guides and recompiled them with a bit of tweaking.
        kudos to you guys and any noobs like i was (still am?) please take a read.
        is this the most basic nooby's guide on here?
        have a 500c but not a clue (not even of what FTP is!) and was disappointed to discover that it wasn't Plug & Play as i was informed.
        Anyway, I'm keen to go through it all myself - but i need a step by step guide in layman's terms...
        just imagine i'm operating on your genitalia while on the phone to a surgeon..
        thanks.
        • leftwinger
          • Jun 2009
          • 12
          #64
          I all, I'm trying to get the keys and scce files from my pc to Dreambox but when using FlashFXP to do this it wont drag n drop or copy and paste the files...........it just says file transfer failed..........do you need the Null Modem connection to do this this as I'm connected via ethernet to my router........but it doesn't wanna tranfer the files to the dreambox.......cheers, Chris.
          • evildan
            • Jun 2009
            • 5
            #65
            Why do i get video not sync with audio after watching a particular channel for some time? After i switch channel, it syncs again..can anybody help?
            • Egzon123
              • Jun 2009
              I can't download it. :S
              • wilf
                • 1618
                #67
                because your a new member, make a few posts and it will allow you should start with an introduction.
                • Beenthere
                  • Jun 2009
                  • 7
                  #68
                  Just done my new DM500C in under 40 min with the help available here. Many thanks to all those leading the way (keep up the good work).
                  • pangster
                    • Jun 2009
                    • 30
                    #69
                    the guide is good - but slightly incorrect in the fact that it tells you to copy the files to var_init when infact this is a read only location and the actual folders you need to copy to are located in var (not var_init)
                    HTH
                    • NinjaXP
                      • Jun 2009
                      #70
                      thanks for this. When you have to come back to something you done 2 years ago, it is always the noob guides you go to so you remember what you had done (did that make sense?)
                      • mds
                        • 38
                        #71
                        Do the permissions on all the files in the KEYS and SCEE need to be reset to 755 as their parent folder is set?
                        • pringle77
                          #72
                          For some reason i cant access the info in your post
                          • pringle77
                            #73
                            dreambox dm 500-c
                            can anyone help me fix my dreambox dm 500-c ,i cant access the info on this site
                            • gzrfkq
                              • 8
                              #74
                              Hi all
                              does this download contain info on where to obtain the scce files,thanks
                              • Walkinmyshadow
                                • 712
                                #75
                                It does.. but it's old scree files and outdated.. other than that go with the guide.
                                If you need new roms (scree) send me a pm and i'll oblige
