SKY BOX OFFICE CONFIRMATION
  • toto67
    • Feb 2008
    • 178
    #46
    Think hes given up m8.......
    • toto67
      • Feb 2008
      • 178
      #47
      Right,is there ANYONE else up at this god forsaken time trying to get this to work? Try these settings instead of the ones already posted to see if this helps guys
      VPID : 0515
      APID : 0663
      To note: These are for Glagow TW are folks.....
      Ok,so as NO confusion and edited post..
      Go into scanning menu...
      Menu > Setup > Service Searching > Manual Search
      Frequency - 555MHz
      INV - ON (ticked)
      Now select Yellow button (PID)
      Name - Sky Box Office Sports
      Provider - 555 or 507 or 627
      Video PID - 0515(instead of 0203)
      Audio PID - 0663(Instead of 0297)
      PCR PID - 007b
      Teletext PID - 0243
      TSID - 0007 (for ex-tw)
      TSID - 007a (for ex-ntl)
      TSID - 0064 (for ex-c&w live events channel)
      TSID - 0065 (for ex-c&w SBO PPV2)
      ONID - 1020
      Service ID - 06a4 (for ex-tw)
      Service ID - 0275 (for ex-ntl)
      Service ID - 0067 (for ex-c&w live events channel)
      Service ID - 007c (for ex-c&w SBO PPV2)
      No DVB - Untick
      Use SDT - Tick
      Save settings (BLUE)
      Start scan
      Should only take a few seconds and should return 2 new services.
      Exit out of the menus.
      Press OK then RED (All Services) and scroll down to Sky Sports Box Office. Should work ok.
      If provider 555 doesn't work, try 507.
      • shaz4215
        • 83
        #48
        what about london folk? :P
        • Ballistic
          • Oct 2008
          • 243
          #49
          I tried al these and got bugger all on SBO bt it was on channel no 231 PPV sub if its any help
          come RH
          B
          "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
          • Scarface
            • 92
            #50
            If Devilfish`s tut is a generic one, what settings change from region to region, the frequency stays the same, but three options for Provider, which none work for me. toto67 posted setting's with diff VPID and APID, and states you have to reboot, do you reboot only if it finds any new services?? No matter which provider I enter it only ever finds 1 transponder but never any new services. Is there anyway to find out the settings for a particular region from somewhere?
            • X-PAC
              • Oct 2008
              • 45
              #51
              come RH
              B
              any chance you could post your stream info?
              • MrJayT
                • 20
                #52
                channel 231 is channel 5 for me
                • caveman_nige
                  • Feb 2008
                  • 4920
                  #53
                  Well how did this all turn out, did any of you guys manage to pick up the channel last night/this morning. Personally, after finding out in the early evening that i was looking at the wrong channel i tried the guide from DF for a while and found ~~~~ all. Lets just say that after that I could not be arsed and went onto other things...
                  Those that have it, stream info would be good so that we can all set it up for future use etc...
                  • MrJayT
                    • 20
                    #54
                    VPID : 0515
                    APID : 0663
                    Frequency - 555MHz
                    INV - ON (ticked)
                    PCR PID - 007b
                    Teletext PID - 0243
                    ONID - 1020
                    No DVB - Untick
                    Use SDT - Tick
                    Start scan
                    also no luck
                    • MrJayT
                      • 20
                      #55
                      did ANYONE actually get the channel full stop??
                      • Donnie Darko
                        • 442
                        #56
                        Yes...........
                        Checkout the RED stickies massive amount of info and effort been put into them.
                        • caveman_nige
                          • Feb 2008
                          • 4920
                          #57
                          I get all the other channels you listed with the info you provided Donnie Darko but not the SBO PPV2...
                          But I had those anyway..
                          • caveman_nige
                            • Feb 2008
                            • 4920
                            #58
                            OK, here its is from my settings.. Found it at last, to be honest it probably already there. I went into User Bouquets (pressing OK from any TV channel) and pressed the red button for all services. I scanned through there and found all the attempts i had made to manually scan for it and just flicked through them. None had the signal indicator bar beside them.. howver one of them had boxing one.. details are below..
                            Stream Information
                            Service Name: sky box office sports
                            Service Provider: 627
                            Service Reference: 1:0:1:7c:65:1020:0:0:0:0:
                            VPID: 0206h (518d)
                            APID: 02a6h (678d)
                            PCRPID: 0286h (646d)
                            TPID: 02d6h (726d)
                            TSID: 0065h
                            ONID: 1020h
                            SID: 007ch
                            PMT: 0020h
                            Video Format: 544x576 16:9 25 fps
                            Frequency: 627 MHz
                            Symbol Rate: 6952 KSymbols/s
                            Inversion: Yes
                            Modulation: 64-QAM
                            FEC: Auto
                            • yamar1
                              • 970
                              #59
                              got it on dbox no problems whatso ever, no messing it was there when i switched the channel on, couldnt get it on the dreambox, the dreambox seems a stresser trying to get it to work . a neutrino image on the dreambox would pick it up i would imagine. as thats whats on the dbox.
                              Faster than Faster
                              • birkenhead
                                • 61
                                #60
                                SBO is still transmitting the boxing right now, did have a problem last night, after entering the details, was getting a reply back saying the ONID was in use when tried to press save (blue button)... or something along them lines, so delete the channel 515 which was using very simluar info.
                                re-entered the details then it worked fine.
                                hope this helps someone.
