by the way i can only get this channels on annalog tuner
Sony Bravia with DBD-C Tuners (No Box Required)
Dont select anything just select the - from the list and scan you should get loads more.Comment
Basically when you go to auto startup you will have options of language countries etc.
Under countries you will have all the countries listed, select one which has nothing in it but "-" and also set everything to auto when scanning and select full scan.
Let me know how you get on.Comment
Hi folks,
Newbie needs help :P
I have a Bravia with CAM slot and got all the relavent bits and pieces (infinity USB, Fun5 & Zeta Blue). Problem is, i cant get the TV to see the CAM. I have also tried reading the CAM in my laptops PCMCIA and the whole system crashes
I am thinking its a faulty CAM but is there any way (Other than CAS) to check if the CAM is ok?
Thanks in advance!
N1zComment
Re cam
If you know someone with a satellite receiver with cam slot (not sly) it will show up if it is working , if nothing comes up you will has to get a cas or funcards to reprogram it.Hi folks,
Thanks in advance!
N1zComment
You cam may be blank so will not be recognised by TV slot (Sonys are like that) ,you will have to check it in a satellite box first if it is not seen by that you may be in trouble and have to fully program with a cas otherwise if seen ok get your funcards and program the cards then put in cam in receiver and it will put the software on your cam.
Hope you get sorted m8.Comment
thanks John.You cam may be blank so will not be recognised by TV slot (Sonys are like that) ,you will have to check it in a satellite box first if it is not seen by that you may be in trouble and have to fully program with a cas otherwise if seen ok get your funcards and program the cards then put in cam in receiver and it will put the software on your cam.
I'm still somewhat confused though. I am reliably informed that the Zeta Blue cannot be programed via cas and must be done by funcard 4/5. I have put the joker fw on the funcard (i think!) but how can I transfer this software to the cam if I cannot access it? Sorry again if I sound like a moran! I appreciate your help m8.
N1zComment
