Sony Bravia with DBD-C Tuners (No Box Required)
  • bugaloo41
    • 1598
    Not my work (all credit goes to kevindj) but thought that this may be of use to certain sony bravia owners (Obviously only those who purchase legit TV from VM )
    Certain sony bravia tv`s come with a built in dvb-c tuner. It appears that this will work on all sony models that have the built in cable tuner on the U and the V series. Unclear about the W version but if they have dvb-c built in it should work.
    Dont know if they are still available but Tescos were selling the 32" lcd KDL32V4000 for ?342. It comes with a built in dvb-c tuner and cam slot.
    When you connect your cable feed to the aerial socket and run auto tune (for digital tv) it will ask if you want to tune for terrestrial or cable. You must add your default frequency; Net ID and Symbol Rate before scanning. The Red has kindly posted these for you here. http://www.digital-kaos.co.uk/forums...a-codes-29260/
    Now scan and it should pick up all digital channels.
    Now to clear the encrypted channels you will need a cam and card. Any card will do mosc; atmega; tit; au fun etc. Your b/k and IRD will be displayed on the cam.
    Cams that will work are:
    joker, icecrypt, zeta neotion based cams that have been flashed with 0.79 firmware, any cam that can be flashed with joker 0.79 will work. Note the newer type zeta blue cams can't be flashed! You will need a cas interface and dump of joker 0.79 to flash the cam with.
    Cams that dont appear to work:
    x-cam, x-cam platinum, nagravision cam, these cams and some others conflict with the tv you cannot get the tv to see them in the ci menu.
    Kudos to kev.
    Tutorial, joker etc http://www.mediafire.com/?sharekey=5...4e75f6e8ebb871
  • 1184jap
    • 24
    Where can I get a copy of Joker 0.79 firmware.
    • bugaloo41
      • 1598
      Here it is
      • fatyead
        hi just found this site. i have a diablo 2.3 cam i can see it in menu but not sure how to set it up.
        any pointers would be great !
        • 1184jap
          • 24
          @ bugaloo41
          Thanks for the file.
          • bugaloo41
            • 1598
            Read the tutorial mate that will help. If you are still stuck post back and i will try my best to help. I dont have a sony tv but should work through this ok.
            • cactikid
              • 12017
              i wonder will other makes change aswell to incorporate a dvb/c tuner
              • dannyrp03
                • 23
                hi ,been using blue zeta (joker),mosc au blockered image 4 a couple of months now ,but everytime i turn tv off and on i have to pull cam out then reinsert ,not a major problem ,just wondered if anyone else had this problem
                • bugaloo41
                  • 1598
                  Danny
                  Your not alone mate most (if not all) seem to suffer from the same bug.
                  • 1184jap
                    • 24
                    @ dannyrp03
                    Have you got a copy of mosc au blockered image 4 to give me.
                    • dannyrp03
                      • 23
                      cheers bugaloo, is it just the zeta cams or does the diablo do it aswell ,@ 1184 jap there plenty of images about the forums m8 just make sure u get the right provider best, regards danny
                      • bugaloo41
                        • 1598
                        seems to be all cams mate.
                        • j-lee
                          • 5
                          Re. pulling cam out to reset
                          Not got one myself, but for those of you who have to pull the cam out and reinsert it to get it to work.
                          A friend of mine has this set up and he had the same problem, so after some searchin on net he changed the cam id to all zeros and this seemed to clear the prob.
                          • majpat0
                            • 44
                            hi so can u watch the hd channels in full hd
                            i know only bbc hd is on cable
                            • bugaloo41
                              • 1598
                              you dont seem to be able to get bbc hd as far as i can gather. think it could be something to do with the tv having a dvb-c1 tuner. apparently you need a dvbc2 tuner. just what i have read mind.
