New 2015 Enigma2 Boxes DVB-C and DVB-S2 Zgemma Star H1 & 2S
  • digicon
    • 8261
    #196
    Originally posted by cactikid
    i have the sat version of the nano se to replace my solo,wonder will that box be small and have a free magic eye.
    curious if anyone using zgemma on cable in ireland??
    Same size apparently with an added DVB-C/T/T2 tuner specs:
    • Fully MPEG-2, MPEG-4 & H.264 Compliant
    • DVB-S & DVB-S2 Complaint
    • 1x HD Satellite (DVB-S2) Tuner & 1x DVB-T / DVB-T2 / DVB-C Hybrid HD tuner
    • 751MHz Broadcom Dual Threaded MIPS Processor
    • 256 Mbyte NAND Flash & 512 Mbyte DDR3 Ram
    • Linux Open Embedded
    • Output Resolution: Full HD 1080p, 1080i, 720p, 576p, 576i & 3D Ready*
    • 1x Smart Card Reader
    • 1x Common Interface (CI)
    • External IR Sensor
    • HDMI Output
    • Dolby Digital Plus compliant via optical S/PDIF output
    • 2x USB 2.0 Ports (1x front and 1x rear)
    • Ethernet Port
    • Unlimited Channel Memory
    • Composite Video Output with Audio Channels
    • Super sensitive tuner for very weak signals and weak transponders
    • Less than 1 second channel change
    • DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
    • Extended EPG and programme reservation on EPG
    • Support for multiple audio language broadcasts
    • Supports PAL/NTSC systems
    • Parental Control
    • SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
    • 4:3 & 16:9 screen formats
    • Timer & multi-event timer functions
    • Automatic FEC and PID detection and manual entry of PID values
    • Real time clock
    • Teletext & Subtitle support by OSD and VBI
    • LNB short circuit protection onboard
    • Universal Remote Control
    • 1W Standby power consumption option
    • 12V DC
    • cornorth
      • Nov 2013
      • 28
      #197
      Is it possible to have the EPG and recording 2 programmes, pausing capability etc from a single USB stick/drive whilst the other port is occupied by the Wi-Fi?
      • digicon
        • 8261
        #198
        I dont see why not but maybe a good idea to try a powered external drive rather than having the USB supply power to the drive and wi-fi stick, Puts less strain on the PSU unit
        • cornorth
          • Nov 2013
          • 28
          #199
          What about the capacity requirements?...
          For instance how much would be required by the EPG and other online TV plugins etc?
          How much capacity would a 2hr programme require?
          • digicon
            • 8261
            #200
            Use an Externally powered hard drive at least 500gb especially if your thinking about doing a lot of recording, a 2 Hour program in HD could take up anything between 7gb to around 14gb
            EPG takes up very little space
            • cornorth
              • Nov 2013
              • 28
              #201
              seeking to get all setup using wireless setup and looking like sly etc with all plugins
              need assistance in getting wireless setup with "the c** thing" and ready to go - have managed to flash the sly skin version so far
              the box recognises the dongle previously in my f5s and finds my router but can't configure
              • BRUTUS
                • 37
                #202
                Hi all,
                i am having problem to play movies, recorded from the net onto my usb stick.
                I can record and playback from the zgemma box but anything recorded from a tiers device won't play (not even seen) by the zgemma...
                Thinking of a missing plugin, but which one??? An helping hand will be appreciated.
                Thanks guys and girls
                • cactikid
                  • 12017
                  #203
                  are you saying that you have another place for recordings on network or pc and you want to play them on your box,maybe samba or n** to be seen on network.
                  any usb or hdd needs mounting to be seen if thats your issue.
                  • DJGonzo
                    • May 2010
                    • 42
                    #204
                    I will be purchasing this soon. Just to make sure, the H1 works with both Satellite and DVB-C?
                    I have a cable sub, so I just stick my SmartCard in it and it will work? Then when I get satellite, I can switch between the two, right?
                    • BRUTUS
                      • 37
                      #205
                      That's correct
                      Not correct. You need to do some diggins...we can't discuss that here. Against the rules
                      Correct
                      • DJGonzo
                        • May 2010
                        • 42
                        #206
                        Thanks for the reply. I ordered 2. Let's see what happens
                        Its against the rules talking about a legit sub? I'm not saying sharing or softcam. I'm saying grab the irdeto card from my cable sub (which I pay for) and putting it in this receiver.
                        • digicon
                          • 8261
                          #207
                          I am afraid the latter is Impossible
                          • i1646tvk84423
                            • Jan 2013
                            • 36
                            #208
                            Dear people who already have this box, u know DM800se renders the OSD and skin at 720p, and scales it up to 1080p when u use HDMI 1080p.
                            Is this the case for Zgemma H1/H2?
                            I'm hoping it does 1080p natively cos 720p -> 1080p is not ideal.
                            • rackha
                              • Jul 2012
                              #209
                              What is the difference between the h1 and h2 and do these boxes only come with a white case
                              • digicon
                                • 8261
                                #210
                                ZGemma H1 : 1 x DVB-S2 satellite & 1 x DVB-C/T Cable/Terrestrial receiver
                                ZGemma H2 : 2 x DVB-S2 satellite Tuners
