Please upload Maplin USB To Serial RS232 Drivers :D
  • dasteph
    • 1293
    #106
    http://www.gilsson.com/usb_drivers_download.htm
    • MaccaPM
      • Aug 2009
      Also in need of the drivers for Maplins USB to RS232 converter - damn Vista!
      • dasteph
        • 1293
        #108
        USB to Serial Adapter driver downloads and documentation
        • dasteph
          • 1293
          #109
          Originally posted by greeney
          I was actually looking for the COM port assigner you got on the disk - anyone have a copy of that?
          Cheers,
          /Paul
          you can change the com port in device manager-com ports-properties-port settings-advanced there you will see port number with drop down box change it to ports 1-4 which ever is free.
          • rsbestos
            • Sep 2009
            want to see the difference with the real Prolific Drivers
            Anybody compare the maplin drivers with the prolific driers?
            • sozuki
              • Sep 2009
              • 5
              #111
              hl 340 no drive unknown
              • zuron007
                • Sep 2009
                Thanks for the files, i will try and download them shortly and use them with win7 7100. I am hoping that this will work better than the installation pack that prolific provides.
                In case anyone else tries it with Win7,
                - Compatibility mode wont help (Tried XP SP3, Vista, Vista SP2)
                - Windows Update search for drivers wont find it either
                Ill let you know how it works if it works!
                • pgarriock
                  • Sep 2009
                  Doncha love mini-cd's
                  I have a slot loading dvd on my lappy and it doesn't like my mini driver cd, so I will try with the one posted here.
                  Cheers,
                  PeeGee
                  • mixed_londoner
                    Originally posted by westkill
                    i think these are the drivers for mine
                    will these drivers work for windows 7, for some reason my laptop install hid drivers instead of what ever it is that works with kryptview
                    • blakeyewarrior
                      • 5
                      #115
                      vista drivers, clever stuff
                      i been a member about a year an done o few boxes but 1 is givin me BIG probs, ad to get new cable n lot, guna try these driver cuz maplin 1's o PooooooooooooooooooooP.....!!!!!!!!!
                      • ianmac
                        • Oct 2008
                        • 922
                        #116
                        These are the Maplin cable drivers that I used on Windows 7:
                        System Requirement:
                        . Supports the following Windows OSes:
                        - Windows 98SE
                        - Windows ME
                        - Windows 2000 SP4
                        - Windows XP SP2 and above (32 & 64 bit)
                        - Windows Server 2003 (32 & 64 bit)
                        - Windows Server 2008 (32 & 64 bit)
                        - Windows Vista (32 & 64 bit)
                        - Windows 7 (32 & 64 bit)
                        I Have got other drivers for MAC, Linux & windows server if anyone wants them.
                        Hope this helps
                        Ian
                        • ianmac
                          • Oct 2008
                          • 922
                          #117
                          Originally posted by 53hat
                          Shuoldn't be this hard to make a cable work!! ....have to post to down load so here it is.
                          Then you should have read your welcome email & put your first post in here:
                          Introduce Yourself
                          Ian
                          • caveman_nige
                            • Feb 2008
                            • 4920
                            #118
                            Originally posted by bub
                            I was having trouble with Vista aswell I tried the drivers that came with the adaptor and the drivers on this thread and nothing worked. So I done a bit of searching and used this 'Windows Vista driver for prolific chip USB Serial Adapters' plugged in the Nikkai usb adaptor and Vista recognised it no problem at all
                            this driver also worked on a Win7 install i did last night (see post 23)
                            • rooziek
                              It's work in win7??
                              • sandy128
                                Prolific drivers don't seem to work. Not sure why. I really should remember to keep the CD!
