Starview 5 - firmware
  • peter67ob
    #241
    hi peter here im a newbie to starview 3 and was hopeing that u guys can help me find starview 3 softwear and n2 fix
    • shakennstirred
      #242
      got my starview 5 today and its up and running great after reading this thread
      so thanks guys
      • baza_1969
        #243
        Many thanks guys!
        Hi folks - Got my Starview 5 box, installed the 'TheboxSuperUSB2_v2.03.20090923.BIN' firmware as per instructions on this site...and....it...
        100% works! many thanks for all the old hands on here that are so patient with us newcomers!
        I have a couple of minor issues if anyone could enlighten me..
        1) EPG seems to do a 100% download every time I use it..
        it works ok so I'm not moaning!
        2) Half the time I can't delete my recordings from my mem stick. I hit the green button, then OK - and the dialog box disappears leaving the recording still there. The only way I can get it to work is to switch off the unit at the rear, then back on. The files will then delete in the normal way..
        Any ideas?
        Thanks again
        Baz
        • DESSERTDOG
          • 493
          #244
          Hi Baz
          Epg seems to do that on the SV5 for some reason but once its done it it seems to be ok for the rest of the day .
          Deleating recordings not had any problems with doing that so far m8 i have used Mem Cards Usb Sticks and also a 40gig Hard Drive and all deleated fine m8.
          If i have helped you please dont post Thanks just use the Thanks button
          • amj2305
            • Oct 2008
            • 9
            #245
            Epg does that for me sometimes on sv4 & 5 but no big issue really, not had that problem with recordings i use 8gig usb stick, try reformatting it make sure to do full format/fat32 through the pc.
            • bugzy
              Hi guys, got my starview 5 yesterday installed firmware ok but not pickin up any signal from the sky cable. Am new to this, so probably missed a step or those this box only work with cable tv and not sky...pls help
              • amj2305
                • Oct 2008
                • 9
                #247
                yes starview only works on cable m8. return the said box to where you got it from & get hold of a starview combo that does both sat & cable, thats if you want to stick with starview btw
                • New2Eurovox
                  • 14
                  #248
                  Originally posted by flea3764
                  Anyone else have this problem when putting software onto box?
                  Mine says downloading please wait but doesnt seem to be doing anything, if you had this problem how did you fix it?
                  Imm having the same problem right now
                  been stuck on the downloading screen for about 40 mins,all the wee squares went white but its still at 0%
                  Dont want to turn it off as the warning is at the bottom of the screen
                  Followed the tut to the letter and im using v2.02
                  • laffaklad
                    • 6
                    #249
                    Did you format your USB pen on your pc before putting the software onto it? I made that mistake initially, but after formatting it worked fine.
                    • john1995
                      • 4
                      #250
                      help
                      Just got my starview 5 and got this file
                      The only problem is that its an ISO file and I have seen on the forum that it should be a WinRar file
                      Help Please
                      • john1995
                        • 4
                        #251
                        Its ok I think that I have got it worked out.
                        • john1995
                          • 4
                          #252
                          Done it
                          Wasn't as hard as I thought or maybe just dumb luck??????
                          • PAUL70
                            • 8
                            #253
                            Hi all i cant seem to turn on the EMU menu on my Starview 5 The Box Super usb 2
                            • boomer39
                              • 2818
                              #254
                              see my reply in your other post!!!!
                              YNWA..
                              • atol1971
                                cheers you guys,bought a starview 5 today followed all the info and im up and working. (took a couple of attempts but got there) ta!
