Starview 5 - firmware
  • philipw
    New to this
    I am also new to this, it would be good to know were I can pick a good cheap box up from.?
    And ideas?
    • irishbull100
      sv5
      hi, totally new to this, just bought an sv5 box as a present for xmas - need to know what to install to get all the relevant cable channels.. cheers!
      • mak521
        • 13
        #333
        hi guys new to this forum, been usin starview since the 1st box came out many moons ago, just got myself a box usb 2(sv5) when i try to access menu via 1570 it does nothing, cant access the cas system screen to ste my default key, any got any ideas
          have you updated your box m8
          • mak521
            • 13
            #335
            it appears the box has come with pre-installed firmware as when i scan channels it finds all the relevant channels
              try updating it again with latest firmware http://www.digital-kaos.co.uk/forums...90923-bin-902/
              • mak521
                • 13
                #337
                but surley the version wouldnt stop the 1570 form lettin u access the cas system menu
                • smirnoff_rules
                  • 8603
                  #338
                  u need 1.07 at least m8 or link above
                  • satsmo
                    • 6397
                    #339
                    The pre installed firmware is probably FTA only. It will scan all TPs but you cannot access the CAS menu, do as Maca has said and you will be able to do so then.
                      it could be the first version think that had some problems..
                      • DESSERTDOG
                        • 493
                        #341
                        Yes it did on some boxes m8 works ok on mine but the second release is what you need its in downloads m8 its not the version smirnof said i think its v2.03 there are only two versions that i know of for the Sv5 Its here:
                        check out the tut while your there it may help
                        If i have helped you please dont post Thanks just use the Thanks button
                          Originally posted by DESSERTDOG
                          Yes it did on some boxes m8 works ok on mine but the second release is what you need its in downloads m8 its not the version smirnof said i think its v1.03 there are only two versions that i know of for the Sv5
                          by the way that tut is spot on well done dd..maca..
                          • mak521
                            • 13
                            #343
                            many thanks lads got it workin with version 2.03
                            • clf-gas
                              Many many thanks guys, esp Satsmo and DD.
                              Got my box up and running no problem.
                              • daleski
                                Hi, i've bought my starview 5 box today. I've downloaded and put onto usb the
                                TheboxSuperUSB2_v2.03.20090923.BIN
                                firmware.
                                But when i click on usb on the menu, it goes to the data transfer page and then
                                "not a file of this IRD"
                                Is there a certain way the file needs to go on the usb stick? I just dragged it on there. The stick says that it's formatted to fat32 when i checked.
                                If anyone could help that'd be great.
