Starview 5 - firmware
  • Porky1978
    • Sep 2009
    • 10
    #76
    I guess people are impatient because, like me, they were told that the firmware for the starview 4 box would work. Thats what i was told by the nice man from Wiz Sat
    • chubbles
      • Sep 2009
      Ok so i'm considering buying starview 5. However I was wondering if there are going to be major problems with the firmware for the first few months?
      so would it be better to get a starview 4 instead because it's tried and tested as it were?
      Cheers for any help
      • steve&deb
        • Sep 2009
        hi bought one of these starview 5 boxes delivered today havnt got a clue what to do have my memory stick (ready 4gb) can someone please give a newbie a really easy description of what to do thanks so much
        • slipdog
          • 6
          #79
          Hi can anyone send me even the flakey firmware for this box so can at least plug mine in !
          Thanx
          • DESSERTDOG
            • 493
            #80
            Cheers for any help
            Most hardware and software has teething problems the choice is entirely yours if it helps lots have been sold even i have one on order
            If i have helped you please dont post Thanks just use the Thanks button
            • badapple
              • 2041
              #81
              Hey guys BE VERY CAREFUL!!!
              my m8 picked up a starview 5(usb2) last friday and tried to load the SV 4 firmware on it and now it fcuked up, its showing 0000 and he cant get any response from it! Its just frozen.
              So dont try to load any old firmware on it, just wait for the correct firmware to be released or your box may fcuk up as well!
              SLOWLY, OUR FREEDOM IS BEING ERASED.
              SOON, WE WILL JUST BE A NUMBER.
              IF WE DON'T FOLLOW, WE WILL BE ERASED.
              • DESSERTDOG
                • 493
                #82
                Thanx
                Im sure that you dont need anything else to get freeview so you can plug it in now
                • rampantic
                  • 46
                  #83
                  yes, you can get the freeview channels on the sv5 even without the software, just go into instillation and scan for channels - and here's hoping the software gets here soon...
                  • Wizard1
                    • 25
                    #84
                    Hi All
                    Its here, seems to work ok. Check the Downloads section.
                    Regards
                    • satsmo
                      • 6397
                      #85
                      Yes its here and on a few other sites for a while now. Thanks to the authors. Firmware link updated as one was a direct download and two appeared at the same time. Link is here http://www.digital-kaos.co.uk/forums...2-02-2009-884/
                      Sticky this for now and members can leave feedback, cheers Wizard1 for the upload.
                      • martyn67
                        • Sep 2009
                        • 5
                        #86
                        put this on my sv5 all loaded ok but when i go to sp1 for update seems to be taken ages ?
                        • martyn67
                          • Sep 2009
                          • 5
                          #87
                          when i set emu i pressed menu to exit when i should have pressed exit DOH btw it all works fine so far
                          • Porky1978
                            • Sep 2009
                            • 10
                            #88
                            In, on, done, sorted......Hats off and many compliments to the boffiins!!
                            • DESSERTDOG
                              • 493
                              #89
                              Dam where is my box Grrrrrrrrrrrrrrrrr
                              • DESSERTDOG
                                • 493
                                #90
                                Those that have the box and got it up and running it would be nice to have a small write up from you with your comments please if you have the time.
