Starview HD Combo LAN & NON LAN STBs
  • Babyface786
    • 27
    #91
    Originally posted by Thesven
    Hi just got the Hd lan combo and looking into the set up next downloading the firmware all very scary only used to some think with a set of wheels
    put firmware file on root directory of USB, power of box, insert USB, Power on box, seclect USB from menus, select firmware file, select SW+ALL DATA. Do not remove USB until box has rebooted fully. Scan your cable area for channels and keep of the adult channels!!
    http://gifts.freebiejeebies.co.uk
    • pongo snodgrass
      • 178
      #92
      Originally posted by Babface786
      select SW+ALL DATA.!!
      SW is the latest FW, but whats "ALL DATA"...is that the CCcam software..etc?
      • Babyface786
        • 27
        #93
        Not sure, but even for other boxes the installation file asks you to select all data. i though it was the channels but that you have to make/restore backup yourself. Even for the non-lan box it asked you to select all..so my advice is just do as it says.
        • Babyface786
          • 27
          #94
          ok ta....will upgrading to the latest 22 january fw erase all my channels....or will they be left as they are ? i mean the channels for sky...not too bothered about the cable channels list........cos its taken me ages to sort out and delete the unwanted ones....ta
          Hi, can you please upload your channels dump file on here somewhere, as many people would be interested. Does your channels list contain only the FTA/FTV channels? no point having the scrambled ones becuase the box does not decrypt them.
          I my self is having problems doing a satellite channels search/scan.
          thanks.
          • pongo snodgrass
            • 178
            #95
            yes..i have have the scrambled channels..done my own favs...
            • Babyface786
              • 27
              #96
              I am looking for just the satellite channels dump file..please share.
              • alex123
                • 832
                #97
                [QUOTE=Babface786;441286]I am looking for just the satellite channels dump file..please share.[/QUOTyes i would like a channel dump for sky but only scrammbled one LOL
                • amberman62
                  • 46
                  #98
                  Hi trying to load from USB and getting .. update fail check your USB memory... also does this box combo lan have an auto sort for channels
                  • Babyface786
                    • 27
                    #99
                    yes, works well on cable channels.
                    • Babyface786
                      • 27
                      #100
                      [quote=alex123;441509]
                      This link should help:
                      Thanks to Bigmaq!
                      • combouser
                        • Feb 2010
                        hd combo installation
                        Inspite of firmware box dosen't work. please advice.
                        • chetan.chauhan
                          • Feb 2010
                          Hi Im new to this so I maybe asking a really silly question:
                          I currently have a Starview HD Combo plus box, with the LAN port on the back. I can see majority of the channels however Ive got limited HD channels, such as veiwing non FTA in HD (ie S**y S***ts in HD). Any one with any ideas how to get these channels? Your help will be much appreciated
                          Cheers
                          • pongo snodgrass
                            • 178
                            #103
                            not my work..found elsewhere
                            "It is basically the GrooveRider_HD_Combo_+_0122 image with Favourite Channels set up as close to SKY UK"
                            see HERE
                            • robbeno
                              • Feb 2010
                              • 389
                              #104
                              hi im reading all messages on this hd combo, an it looks like most are having problems of some sort, is it worth me buying one of these combos or should i just get the older starview version wich im told are not a problem an easy to get up a running.
                              • robbeno
                                • Feb 2010
                                • 389
                                #105
                                or do u think i should wait a wile an see wa happens as im told there all gettin scrambled real soon, they already done so in yorkshire.... so im told
