New Firmware Starview 3 - 8.04e
installed 10 minutes ago - SEEMS to be working. touch wood.
massive thanks to whoever took the time to fix this.Comment
audioblackout, how did you install the firmware because im having problems:
1) im plugging int he serial cable to the pc and to the box.
2)Turned on the box, it displays the channel number
3)I open the GTRom_Super_8.02e.exe and click download.
But then it says Flash Update Failed...
am i doing anything wrong?Comment
few questions....
i can only see loader file should there be a bin file?
is this just for the starveiw 3 super?
and is it working?
cheersComment
Yeh same, i got the old v4.00 of the GTRom and that still works with my box, tested it by uploading from the box...
So it seems there is something wrong with this new GTRom loader, it doesnt seem to work with my box, doesnt communicate with it.
Seems few other are having the same issue, need someone more advanced to help us out ...Comment
If someone can give us the .bin file of the update then we can use the old version of the GTRom loader to download the update onto our box.Comment
Hi Lolly,
The cable you need is a serial cable, it must have come with your Starview box, then all you do is connect the cable from your pc to your starview box. Then download the update, run it and click download.Comment
However, i am still having problems with the new update failing to connect to my starview box.
Someone must have some ideas?Comment
