After installing the wads in the fix file. When you go back to the wii menu you will have updated gx and the channel will still be there and you will have a new channel which is the ios installer. I use mmm (multi mod manager)13.2 so I can't comment on wad manager. You then install from the installer channel following the instructions in the fix file
Have tried every thing on this one. The best I can get is through CFG loader running Ciso249[56] v 6 but this still freezes from time to time. Can get usbloader GX to work
i like most have had problems with driver san francisco so was glad when i stumbled upon this site and have managed to get it working using the fix and have played a few levels without stopping now on to tintin.
Still can't get it to work. I've tried IOS250 base 57, 49 base 56... USB loader GX...
I'm using an NTFS partition drive with a wbfs folder, but it doesn't seem to be working. Rough life. I'm gonna try the linked file in a sec and report back, but I'm having no luck.
If you are using gx 2.3 with the d2x v 7 wad pack from the d2x thread it loads on all global settings. Don't need to touch a thing. By the way global settings for that version of gx is cios 249
Updated with those instructions and it's still not working.
On usb loader gx 2.3, using all of the d2xv7 patched in, still no dice
Does it matter that I'm on System Menu 4.2 or anything? All my other games work, but not Driver
