Help with softmod Wii 4.3e
  • Keithuk
    • 2264
    #31
    Originally posted by Keithuk
    When PriiLoader install starts it says at the top it uses IOS58 do a sysCheck to see if thats installed.
    Do you have hacks.ini on the SD root and hacks_hash.ini in the apps\priiloader folder?
    I've said that PriiLoader uses IOS58 is that installed on your system?
    Originally posted by CRITCHK
    right so I guess I had to many priiloader folders.
    I have a folder called Apps
    inside is a folder called Prilloaderv0.7 plus hacks
    inside are boot.dol hacks.ini icon.png and meta.xml files.
    So is this all I need to install from HBC?
    when I load HBC will what I need come up or do I have to got to a certain menu?
    The apps folder must all be in lowercase else it won't read it.
    It doesn't matter what the sub folder name is HBC just links to all boot.dol's in each sub folder. The icon.png is just the picture for that app that shows in HBC.
    Keith
    2010 Golf GTD (170)
    • ck-ok
      • 2592
      #32
      Try again
      On my Sd Card
      the folder structure you have should now work
      start homebrew channel you should see all your apps displayed navigate to priiloader and click load this should start your installation process.
      keith ios58 is part of the 4.3 update which he says he's on so yes he has it.
      • CRITCHK
        • Jan 2012
        • 41
        #33
        I have installed prilloader now, but when I try to install some system menu hacks now (by going to System Menu hacks) I am getting the error, "can't find hacks_hash.ini on FAT device Cant find hacks_hash.ini on Nand
        • ck-ok
          • 2592
          #34
          try copying the hack.ini file to the root of the sd card [ not in anyother folder] and try again
          • CRITCHK
            • Jan 2012
            • 41
            #35
            Coming up with the same error even thou it is in the root of the sd card.
            sd card format is
            hacks.ini file
            apps folder
            in apps folder
            priloader folder
            in priloader folder boot.dol icon.png and mete,xml files
            I have no hacks_hash.ini file anywhere!
            Another problem is
            Also I have tried to load system check from the HBC do you just click on start in HBC and nothing happens.
            For this my SD
            has a folder called apps
            inside files called boot.dol, icon. png and meta.xml
            nothing happens
            • CRITCHK
              • Jan 2012
              • 41
              #36
              also tried with hacks ini file in both root of sd card and in priloader folder.
              • ck-ok
                • 2592
                #37
                sd card format is
                hacks.ini file
                apps folder
                in apps folder
                priloader folder
                Another problem is
                For this my SD
                nothing happens
                download the latest 4.3 system menu hacks from here File:Priiloader hacks.zip - WiiBrew
                • CRITCHK
                  • Jan 2012
                  • 41
                  #38
                  downloaded thanks.
                  Where do I put the hacks_hash ini files in the root or in the priloader folder and what about the other folders all with there own hacks_hash ini files?
                  I have a 3x folder with hacks hash ini file
                  a 4 x folder with 4 further folders 4.0 4.1 4.2 4.3 all with ther own hack hash ini files and another hacks hash ini
                  • ck-ok
                    • 2592
                    #39
                    downloaded thanks.
                    you only need the hack file from the 4.3 folder copy the file and paste it to the root of the sd card and into the priiloader folder just to be sure then try again
                    • CRITCHK
                      • Jan 2012
                      • 41
                      #40
                      Ok moved things about and it's working now managed to block online updates and block disc updates.
                      Thank you all so much for your time and input.
                      Right then what's next!
                      • CRITCHK
                        • Jan 2012
                        • 41
                        #41
                        So after priiloader do I format my SD card and install the wads or the USB loader first?
                        • ck-ok
                          • 2592
                          #42
                          try the thanks button
                          • CRITCHK
                            • Jan 2012
                            • 41
                            #43
                            Is that the scales button!! I have already you are fantastic!!!!!
                            • CRITCHK
                              • Jan 2012
                              • 41
                              #44
                              just found it and clicked some thanks again a million!!
                              • CRITCHK
                                • Jan 2012
                                • 41
                                #45
                                By the way it's she not he! Did you not read my post about being a tech virgin and Fat 32 a large women's clothes size!
