Could you help sort out my wii?
  • deathblast
    • Dec 2010
    • 25
    Hello, recently my wii has stopped being able to load most wii games from my hard drive after spending so much time trying to make them work.
    I've been installing cios after cios trying to fix these problems but now I'm just getting depressed.
    The game I'm trying to get to work is Kamen Rider Fourze(J) but recently Skyward Sword and Rhythm heaven wii (J) has also stopped working (RH just resets and SS crashes and brings up a dump screen)
    I had been using D2X for slot 248 and I've been using all current usb loaders like usb, configurable loader ect.
    Here's a SysCheck if it helps.
    sysCheck v2.0.1 by Double_A
    ...runs on IOS58 (rev 6175).
    Region: PAL
    System Menu 4.3E (v514)
    Hollywood v0x11
    Boot2 v4
    Found 131 titles.
    Found 45 IOS on this console. 8 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): Trucha Bug, ES Identify, NAND Access
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 525): Trucha Bug, ES Identify, NAND Access
    IOS13 (rev 1031): Trucha Bug, ES Identify, NAND Access
    IOS14 (rev 1031): Trucha Bug, ES Identify, NAND Access
    IOS15 (rev 257): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1031): Trucha Bug, ES Identify, NAND Access
    IOS20 (rev 256): Stub
    IOS21 (rev 1038): Trucha Bug, ES Identify, NAND Access
    IOS22 (rev 1293): Trucha Bug, ES Identify, NAND Access
    IOS28 (rev 1806): Trucha Bug, ES Identify, NAND Access
    IOS30 (rev 2816): Stub
    IOS31 (rev 3607): Trucha Bug, ES Identify, NAND Access
    IOS33 (rev 3607): Trucha Bug, ES Identify, NAND Access
    IOS34 (rev 3607): Trucha Bug, ES Identify, NAND Access
    IOS35 (rev 3607): Trucha Bug, ES Identify, NAND Access
    IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5662): Trucha Bug
    IOS38 (rev 4123): Trucha Bug, ES Identify, NAND Access
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS53 (rev 5662): Trucha Bug
    IOS55 (rev 5406): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5918): Trucha Bug
    IOS58 (rev 6175): No Patches
    IOS60 (rev 6400): Stub
    IOS61 (rev 5661): Trucha Bug
    IOS70 (rev 6687): Trucha Bug, NAND Access
    IOS80 (rev 6943): Trucha Bug
    IOS202 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS220 (rev 21006): Trucha Bug, NAND Access, USB 2.0
    IOS222 (rev 4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223 (rev 4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS246 (rev 21006): Trucha Bug, NAND Access, USB 2.0
    IOS247 (rev 21006): Trucha Bug, NAND Access, USB 2.0
    IOS248 (rev 21007): Trucha Bug, NAND Access, USB 2.0
    IOS249 (rev 21006): Trucha Bug, NAND Access, USB 2.0
    IOS250 (rev 21006): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v8
    Thank you in advance.
  • happy_highlander
    • 3535
    There is nothing in your syscheck to say you have priiloader installed so can you please explain how you have made these (j) games region free so that they will work on your (e) system and did they ever work
    • johnb1
      • Dec 2011
      • 82
      i suggested a complete new softmod and your wii is back
      up to date
      • deathblast
        • Dec 2010
        • 25
        up to date
        How would I go about redoing a softmod?
        • deathblast
          • Dec 2010
          • 25
          I'm not sure how but RH just worked first time without any kind of patching but It doesn't work anymore and Kamen Rider has never worked.
          • johnb1
            • Dec 2011
            • 82
            i think you have a wii whit a softmod
            did you softmod your wii?
            if yes , wel start all over again from the beginning
            • deathblast
              • Dec 2010
              • 25
              I might have a problem with redoing the Softmod.
              Will I lose the HBC? If so then I can't since I used the TP disk exploit and I don't have any of the games needed for a newer install.
              • happy_highlander
                • 3535
                download this ModMii5.0.0.zip - modmii - ModMii v5.0.0 - ModMii - Google Project Hosting and run it on your pc follow the instructions and when you get to the main menu select update softmod, You will then be prompted for your syscheck csv file. copy the csv you have just posted into the modmii window and it will download all the files that are out of date for your wii bringing it bang up to date you then just install all the new wads into your wii. Simples
                • deathblast
                  • Dec 2010
                  • 25
                  Thank you I'll try that now
                  • johnb1
                    • Dec 2011
                    • 82
                    if your system is 4.3 you don't need a game anymore
                    all you need than is the letterbomb ta install homebrew
                    • johnb1
                      • Dec 2011
                      • 82
                      or you can do what happy_highlander says
                      thats maybe a faster method
                      • happy_highlander
                        • 3535
                        do not redo softmod just update with modmii and you will lose nothing. If modmii doesn't download priiloader for you then go this thread http://www.digital-kaos.co.uk/forums...riiloader+v.07 and follow the instructions to make your wii region free.
                        • johnb1
                          • Dec 2011
                          • 82
                          @happy_highlander
                          is modmii also taking care of
                          hackmii istaller or don't you need that?
                          • deathblast
                            • Dec 2010
                            • 25
                            I'm trying to use modmii but I kind of feel silly because the text is too small to read and it wants me to enter something.
                            • deathblast
                              • Dec 2010
                              • 25
                              Oh wait I fixed it, I can read it now.
