Could you help sort out my wii?
  • deathblast
    • Dec 2010
    • 25
    #31
    Originally posted by happy_highlander
    That syscheck is correct you have the d2x cios installed but as ck says ios 36 isn't patched but 236 is give me 2 mins and I'll add the patched ios 36 from my nand to this post.
    Edit......... here you go Digital Kaos - Downloads - ios 36 v3608
    Tried to install it using MMM wad manager and got an error instantly "Title (-4100)"
    • happy_highlander
      • 3535
      #32
      Well do as ck says and select install patched ios36 in the mmm menu
      • Keithuk
        • 2264
        #33
        Yes I do use MMM and all the wads install just fine.
        IOS245 (rev 21007): Trucha Bug, NAND Access, USB 2.0
        IOS246 (rev 21007): Trucha Bug, ES Identify, NAND Access
        IOS247 (rev 21007): Trucha Bug, NAND Access, USB 2.0
        IOS248 (rev 21007): Trucha Bug, NAND Access, USB 2.0
        IOS249 (rev 21007): Trucha Bug, NAND Access, USB 2.0
        IOS250 (rev 21007): Trucha Bug, NAND Access, USB 2.0
        IOS251 (rev 21007): Trucha Bug, NAND Access, USB 2.0
        He hasn't installed any dx2 wads IOS245-IOS251 from what that report shows.
        IOS245[37] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
        IOS246[38] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, ES Identify, NAND Access
        IOS247[53] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
        IOS248[55] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
        IOS249[56] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
        IOS250[57] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
        IOS251[58] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
        Digital Kaos - Downloads - d2x v7 Final
        Keith
        2010 Golf GTD (170)
        • deathblast
          • Dec 2010
          • 25
          #34
          I just reinstalled those using mmm wad manager.
          • ck-ok
            • 2592
            #35
            is there any change?
            • deathblast
              • Dec 2010
              • 25
              #36
              Unfortunately not I've tested it in all loaders too.
              Although when I try to load it in Neogamma using the use correct ios setting it tries to load it with ios56. but then freezes on that screen.
              • ck-ok
                • 2592
                #37
                try starting mmm select install and patch ios36 from the menu
                • deathblast
                  • Dec 2010
                  • 25
                  #38
                  Sorry if I'm being a bit of an idiot but I'm really trying.
                  So I open MMM click on install & patch IOS36, then do I use Express mode or normal mode?.
                  • ck-ok
                    • 2592
                    #39
                    try express if it dont work try normal
                    • deathblast
                      • Dec 2010
                      • 25
                      #40
                      Got an error using express so I'll try normal.
                      Am I suppose to install the wads from SD or the Nintendo servers?
                      • ck-ok
                        • 2592
                        #41
                        nintendo servers
                        • happy_highlander
                          • 3535
                          #42
                          Yes he has it just isn't showing up d2x v7 final. If you look the revision number is correct
                          • mgalyean
                            • Jan 2012
                            Sorting out wii
                            I have a similar issue in that I'm lost in all the IOS and system menu version stuff and need some hints.
                            I have sysCheck output and can remember what I've done (I think!). Should I start new thread or just jump in?
                            • Keithuk
                              • 2264
                              #44
                              Welcome to the forum.
                              Well you can see your system version if you click on Wii Options bottom left then click on Wii Settings the spanner picture on the right. The system version will be shown on the top right.
                              So why have you softmodded to play games from burnt DVD's or from an external USB HDD which part are you stuck on?
                              Instructions for posting you sysCheck report are shown in sysCheck
                              Keith
                              2010 Golf GTD (170)
                              • ribelle
                                • May 2012
                                Hello compliments for the forum and thanks for tips
