Thank's happy_highlander, I think you just solved my problem with your awesomeness
Your welcome but I can't remember ever helping you directly so that must mean you have searched the forum and found the answers from previous posts and for that I thank you, you are 1 of a dying breed
I have sadly encountered some problem... when I'm about to install my priiloader, everything seems to be working out fine, the priiloader install-screen starts and before I have the chance to read or press anything the Wii returns to the HBC.
Does this help?
sysCheck v2.1.0b11 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Homebrew Channel 1.0.0 running on IOS58
Hollywood v0x21
Console ID: 153052092
Boot2 v4
Found 85 titles.
Found 54 IOS on this console. 13 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS202[60] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 6174): Trucha Bug
IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v65535
Report generated on 2012/06/18.
I've tried to install on 236 and 249. Should i install & patch ios36 ?
I've downloaded the two .wad's you posted in this thread but did'nt figure it out how to install them.
Well I would suggest you use sysCheckb17 even though sysCheckb18 is out now.
Because you have a sysCheck.csv you can use Modmii and use the SU option to read the sysCheck.csv file and suggest any newer updates for you. I would say it would suggest d2x v8.0 Final and a newer IOS236.
If he has now used mmm to install and patch ios 36 after posting syscheck it should also have installed 236 latest version
