Could you help sort out my wii?
  • deathblast
    • Dec 2010
    • 25
    #16
    Alright when I went to install priiloader it just black screens and returns to the HBC so i went and installed the wads on MMM first and restarted my wii.
    Now when I go to install priiloader i get IOS236 isn't ES_Identify patched error: -1029 then it goes back to HBC.
    ...Any thoughts?
    • happy_highlander
      • 3535
      #17
      Originally posted by johnb1
      @happy_highlander
      is modmii also taking care of
      hackmii istaller or don't you need that?
      You don't need it he is not remodding just updating but if you have never used modmii download it and run it, you will be surprised at just what it can do. If you want it to it will download all files for softmod and write you a tutorial on how to do the softmod from scratch amongst a host of other things
      • happy_highlander
        • 3535
        #18
        ...Any thoughts?
        yes reload to ios 249 or install this Digital Kaos - Downloads - ios236 v54321 wad first then run priiloader again. Forgot modmii doesn't give you 236, bit silly really
        First choice is to reload to ios 249 as that is the preffered install cios
        • deathblast
          • Dec 2010
          • 25
          #19
          By reload IOS do you mean in MMM then exit it?
          If so Priiloader just resets to HBC.
          And i tried install the wad you gave me using WAD manager in MMM but it stops installing and tells me it could not install.
          • happy_highlander
            • 3535
            #20
            launch mmm then go down to reload ios (or similar) this will bring up a grid of all installed ios on the system navigate to 249 and select it you will then be able to install ios 236 wad into 249 which will in turn let you install priiloader don't exit mmm it will just reload to another ios
            • deathblast
              • Dec 2010
              • 25
              #21
              Oh heck I didn't know I had to hold reset while turning the wii on.
              I do have priiloader.
              • happy_highlander
                • 3535
                #22
                ha ha go to system hacks and make sure wii is region free. I would presume it is.
                • johnb1
                  • Dec 2011
                  • 82
                  #23
                  ok thanks for the reply
                  • deathblast
                    • Dec 2010
                    • 25
                    #24
                    Well after I installed priiloader and all the wads I tested it and nope none of the games work still so I decided to reinstall the D2x cios using the wad pack.
                    But I still get nothing so I came to the conclusion that somehow the dumps were getting corrupted or something so I extracted the game from my hard drive to my computer and ran it with dolphin.
                    It started up.....at 2fps...but it's not broken so now I'm really stumped.
                    • Keithuk
                      • 2264
                      #25
                      Well I don't know which wad manager you are using but MMM tells if each wad installed correctly if it didn't then you repeat the process a couple of times. If that still didn't work then the downloaded files could be corrupt download them again from another source.
                      Do your USB Loaders startup at all?
                      Please post your sysCheck report?
                      Keith
                      2010 Golf GTD (170)
                      • deathblast
                        • Dec 2010
                        • 25
                        #26
                        Yes I do use MMM and all the wads install just fine.
                        Also the usb loaders boot up fine.
                        I redid the Syscheck for you.
                        sysCheck v2.0.1 by Double_A
                        ...runs on IOS58 (rev 6176).
                        Region: PAL
                        System Menu 4.3E (v514)
                        Hollywood v0x11
                        Boot2 v4
                        Found 140 titles.
                        Found 54 IOS on this console. 3 of them are stub.
                        IOS4 (rev 65280): Stub
                        IOS9 (rev 1034): No Patches
                        IOS10 (rev 768): Stub
                        IOS11 (rev 16174): Trucha Bug, NAND Access
                        IOS12 (rev 526): No Patches
                        IOS13 (rev 1032): No Patches
                        IOS14 (rev 1032): No Patches
                        IOS15 (rev 1032): No Patches
                        IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
                        IOS17 (rev 1032): No Patches
                        IOS20 (rev 16174): Trucha Bug, NAND Access
                        IOS21 (rev 1039): No Patches
                        IOS22 (rev 1294): No Patches
                        IOS28 (rev 1807): No Patches
                        IOS30 (rev 16174): Trucha Bug, NAND Access
                        IOS31 (rev 3608): No Patches
                        IOS33 (rev 3608): No Patches
                        IOS34 (rev 3608): No Patches
                        IOS35 (rev 3608): No Patches
                        IOS36 (rev 3608): No Patches
                        IOS37 (rev 5663): No Patches
                        IOS38 (rev 4124): No Patches
                        IOS40 (rev 16174): Trucha Bug, NAND Access
                        IOS41 (rev 3607): No Patches
                        IOS43 (rev 3607): No Patches
                        IOS45 (rev 3607): No Patches
                        IOS46 (rev 3607): No Patches
                        IOS48 (rev 4124): No Patches
                        IOS50 (rev 16174): Trucha Bug, NAND Access
                        IOS51 (rev 4864): Stub
                        IOS52 (rev 16174): Trucha Bug, NAND Access
                        IOS53 (rev 5663): No Patches
                        IOS55 (rev 5663): No Patches
                        IOS56 (rev 5662): No Patches
                        IOS57 (rev 5919): No Patches
                        IOS58 (rev 6176): No Patches
                        IOS60 (rev 16174): Trucha Bug, NAND Access
                        IOS61 (rev 5662): No Patches
                        IOS70 (rev 16174): Trucha Bug, NAND Access
                        IOS80 (rev 16174): Trucha Bug, NAND Access
                        IOS202 (rev 65535): Trucha Bug, NAND Access, USB 2.0
                        IOS220 (rev 21006): Trucha Bug, NAND Access, USB 2.0
                        IOS222 (rev 4): Trucha Bug, ES Identify, NAND Access, USB 2.0
                        IOS223 (rev 4): Trucha Bug, ES Identify, NAND Access, USB 2.0
                        IOS224 (rev 65535): Trucha Bug, NAND Access, USB 2.0
                        IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
                        IOS245 (rev 21007): Trucha Bug, NAND Access, USB 2.0
                        IOS246 (rev 21007): Trucha Bug, ES Identify, NAND Access
                        IOS247 (rev 21007): Trucha Bug, NAND Access, USB 2.0
                        IOS248 (rev 21007): Trucha Bug, NAND Access, USB 2.0
                        IOS249 (rev 21007): Trucha Bug, NAND Access, USB 2.0
                        IOS250 (rev 21007): Trucha Bug, NAND Access, USB 2.0
                        IOS251 (rev 21007): Trucha Bug, NAND Access, USB 2.0
                        IOS254 (rev 65281): BootMii
                        BC v6
                        MIOS v10
                        • ck-ok
                          • 2592
                          #27
                          try start mmm and choose install and patch ios36
                          Install & Patch IOS36:
                          - upgraded to support Nintendo's Sep7 IOS updates
                          - installs patched IOS36 as IOS36 & IOS236
                          - IOS36-64-v3608.wad used as base IOS
                          • happy_highlander
                            • 3535
                            #28
                            He has all the correct cios ck d2x installs better into 236 which he has if you try to install d2x into 36 you will get an error and 250 won't install but you will know better than me if he needs 36 patched then he needs it patched
                            • deathblast
                              • Dec 2010
                              • 25
                              #29
                              You kind of lost me there.
                              So I open MMM with IOS236 loaded and select Install & Patch IOS36, then I select express mode and let it do it's thing right?
                              • happy_highlander
                                • 3535
                                #30
                                That syscheck is correct you have the d2x cios installed but as ck says ios 36 isn't patched but 236 is give me 2 mins and I'll add the patched ios 36 from my nand to this post.
                                Edit......... here you go http://www.digital-kaos.co.uk/forums...36-v3608-1960/
