help with letterbomb please
  • tempo123
    • 344
    #16
    Hi again and sorry for the late reply ( I had to collect the kids) I managed to do a nand back up and saved the 3 files(nand.bin, boot.mii folder, keys.bin) on my computer. I have format again my sd card. What do I do next? Do I run "md5summer.exe" on my computer? I haven't install any wad
    • ck-ok
      • 2592
      #17
      yes thats the next step
      • tempo123
        • 344
        #18
        Another problem, what file do I have to verify sum to check for errors?
        • ck-ok
          • 2592
          #19
          once you have downloaded and extracted the hack pack to your sd card run verify sum .exe if all the files are there then carry on with the process
          • tempo123
            • 344
            #20
            This is what I have done, not sure if ok or not could you please read and tell me:
            On the SD card there is ModPack folder .
            I click on md5summer.exe and windows come up with
            " '.md5' files appear to be associated with a different copy of md5summer. Should I associate them with this one? " yes/no buttons to click.
            I have clicked on "no" and MD5summer little window came up asking me what to verify sums.
            I clicked on ModPack(MD5 checksum container) icon and let run the software. Lots of green lights no errors(as far I understand) and I pressed save. It has been created a file on the sd card " ModPack_Results".
            ModPack_results is a text file with :
            boot.dol OK
            hacks.ini OK
            md5summer.exe OK
            mmmconfig.txt OK
            startup.elf OK
            UsbLoader-GX.dol OK
            apps\hackmii installer\boot.dol OK
            apps\hackmii installer\icon.png OK
            apps\hackmii installer\install OK
            apps\hackmii installer\meta.xml OK
            apps\NeoGamma\boot.dol OK
            apps\NeoGamma\icon.png OK
            apps\NeoGamma\meta.xml OK
            apps\priiloader\boot.dol OK
            apps\priiloader\icon.png OK
            apps\priiloader\META.XML OK
            apps\usbloader_gx\boot.dol OK
            apps\usbloader_gx\icon.png OK
            apps\usbloader_gx\meta.xml OK
            apps\usbloader_gx\rev.txt OK
            bootmii\armboot.bin OK
            bootmii\bootmii.ini OK
            bootmii\ppcboot.elf OK
            config\DOP-Mii.cfg OK
            config\GXGlobal.cfg OK
            config\HBC.wad OK
            NeoGamma\gameconfig.txt OK
            NeoGamma\NeoGamma.cfg OK
            NeoGamma\R3M.wdm OK
            NeoGamma\R3X.wdm OK
            NeoGamma\R3Y.wdm OK
            NeoGamma\RBO.wdm OK
            NeoGamma\RED.wdm OK
            NeoGamma\RF8.wdm OK
            NeoGamma\RHD.wdm OK
            NeoGamma\RJ8.wdm OK
            NeoGamma\RKM.wdm OK
            NeoGamma\RM2.wdm OK
            NeoGamma\RML.wdm OK
            NeoGamma\RNB.wdm OK
            NeoGamma\RNF.wdm OK
            NeoGamma\RSX.wdm OK
            NeoGamma\SMNE.wip OK
            NeoGamma\SMNJ.wip OK
            NeoGamma\SMNP.wip OK
            wad\1OS236.wad OK
            wad\cIOS16-v257.wad OK
            wad\cIOS202[57]-v5.wad OK
            wad\cIOS222[38+37]-v4.wad OK
            wad\cIOS223[38]-v4.wad OK
            wad\cIOS249[38]-v17.wad OK
            wad\cIOS250[57]-v19.wad OK
            wad\cIOS30-v6174.wad OK
            wad\cIOS36-v3094.wad OK
            wad\cIOS50-v4889.wad OK
            wad\cIOS60-v6174.wad OK
            wad\cIOS70-v6174.wad OK
            wad\cIOS80-v6174.wad OK
            wad\IOS38-64-v3867.wad OK
            wad\IOS53-64-v5406.wad OK
            wad\IOS55-64-v5406.wad OK
            wad\LoadMii.wad OK
            wad\Neogamma Channel - R8.wad OK
            wad\USB Loader GX-Forwarder.wad OK
            boot.dol OK
            hacks.ini OK
            md5summer.exe OK
            mmmconfig.txt OK
            startup.elf OK
            UsbLoader-GX.dol OK
            So, could you please tell me if I can go further and install wads please.
            Many thanks for your time
            • ck-ok
              • 2592
              #21
              boot.dol OK
              hacks.ini OK
              md5summer.exe OK
              mmmconfig.txt OK
              startup.elf OK
              UsbLoader-GX.dol OK
              config\HBC.wad OK
              NeoGamma\R3M.wdm OK
              NeoGamma\R3X.wdm OK
              NeoGamma\R3Y.wdm OK
              NeoGamma\RBO.wdm OK
              NeoGamma\RED.wdm OK
              NeoGamma\RF8.wdm OK
              NeoGamma\RHD.wdm OK
              NeoGamma\RJ8.wdm OK
              NeoGamma\RKM.wdm OK
              NeoGamma\RM2.wdm OK
              NeoGamma\RML.wdm OK
              NeoGamma\RNB.wdm OK
              NeoGamma\RNF.wdm OK
              NeoGamma\RSX.wdm OK
              wad\1OS236.wad OK
              wad\LoadMii.wad OK
              boot.dol OK
              hacks.ini OK
              md5summer.exe OK
              mmmconfig.txt OK
              startup.elf OK
              UsbLoader-GX.dol OK
              yeah go for it
              • tempo123
                • 344
                #22
                sorry to bother but seem to be more problems.....
                after launching bootmii the screen is black and console flash the lights around the dvd slot....what should i do now?
                • ck-ok
                  • 2592
                  #23
                  have you extracted all the files onto your sd card ?
                  • tempo123
                    • 344
                    #24
                    I moved the folder ModPack (after unpacking it)onto my sdcard and inside the folder there are varius folders and files and the md5 that i have run before, console still blinking with black screen at the moment
                    • tempo123
                      • 344
                      #25
                      What can i do to go back to the HBC? switch everything off?
                      • ck-ok
                        • 2592
                        #26
                        format the sd card again extract the mod pack to the sd card this time and restart the wii and try again
                        • tempo123
                          • 344
                          #27
                          ok that is sorted I am now on another problem....all the 19wad are ok (good), I went to install priiloader and I arrived to the point that my wii freeze. I have press and hold reset and press and hold the power down so the wii can switch off. So now please where can I find "system menu hacks"?......I think I am nearly there....
                          • happy_highlander
                            • 3535
                            #28
                            Have a look in the modpack that had priiloader in it, the hacks.ini file is usually in there.
                            • tempo123
                              • 344
                              #29
                              so do I have to go to the SD card?
                              • Keithuk
                                • 2264
                                #30
                                There should be hacks_hash.ini in the priiloader folder the hacks.ini goes on the root of the SD card.
                                Have you installed Digital Kaos - Downloads - ios58-64v6175 as PriiLoader uses IOS58?
                                Keith
                                2010 Golf GTD (170)
