No reason why hdd is not being recognised cios are all ok uninstall the loaders and put the latest versions on failing that go back to an older version and see if that works
usb loader cant find HD
Welcome to DK.
That sysCheck looks ok apart from d2x v8.0 missing but that shouldn't stop the HDD being recognized.the following is my system check after I MMMed and did what MMM wanted me to do. I installed your wads, and then I installed MMM's wads. But nada.
My HDD was working perfectly a couple of days ago with both USB loader GX and CFG loader. Now they both dont recognize the HDD.
"I MMMed and did what MMM wanted me to do"
Are you getting confused with ModMii as Multi-Mod Manager (MMM) doesn't tell you to do anything?
If your HDD was recognized before then I don't see why it isn't anymore unless you have changed how you added the games, what format have you used?Keith
2010 Golf GTD (170)Comment
D2x v8 is present.....all the cios ending in 210008 are d2x v8 that is the code numbers for themWelcome to DK.
That sysCheck looks ok apart from d2x v8.0 missing but that shouldn't stop the HDD being recognized.Comment
Well I'm just going by what the sysCheck b18 report says.
IOS245[37] (rev 21008
IOS246[38] (rev 21008
IOS247[53] (rev 21008
IOS248[55] (rev 21008
IOS249[56] (rev 21008
IOS250[57] (rev 21008
IOS251[58] (rev 21008
Mine says.
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
I know its the same rev 21008 but why doesn't it say d2x-v8final with Trucha Bug, NAND Access, USB 2.0, or hasn't he posted a full report?Keith
Just the way it sometimes comes outComment
Yes reinstall whatever loader you are using on the wii that doesn't work or put a different loader on it. Remember you should always extract your files straight to the directory you are going to use them from...I.e straight into teh apps folder on the sd/usbComment
Hello,
i have the same problem stated in the caption.
I have to fix a wii from a friend. He did not know, what happend, but now, the cfg usb loader doesn't detect any usb drive. I tried 2 different harddisks and 1 USB Stick; all of them worked with my soft modded wii. If I start the usb loader on his wii, the counter begins and detect nothing.
When I start wii media player, it detects a USB Drive and I can see all my files on it.
What I did:
new Softmod with current modmii 6.15
tried cfg usb loader and wii coverflow loader
deinstalled hbc and reinstalled
update only missing or newer cios with modmii and syschecker
Syschecker LOG:
sysCheck v2.1.0b18 von Double_A und R2-D2199
...laeuft auf dem IOS58 (rev 6176).
Region: PAL
Systemmenue 4.1E (v450)
Priiloader installiert
Laufwerksdatum: 07.09.2006
Homebrewkanal 1.1.0 benutzt IOS58
Hollywood v0x11
Konsolen-ID:
Boot2 v4
Es wurden 128 Titel gefunden.
Es wurden 54 IOS gefunden, von denen 5 funktionslos (Stub) sind.
IOS4 (rev 65280): Funktionslos (Stub)
IOS9 (rev 1034): Keine Patches
IOS10 (rev 768): Funktionslos (Stub)
IOS11[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS12 (rev 526): Keine Patches
IOS13 (rev 1032): Keine Patches
IOS14 (rev 1032): Keine Patches
IOS15 (rev 1032): Keine Patches
IOS16 (rev 512): Funktionslos (Stub)
IOS17 (rev 1032): Keine Patches
IOS20[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS21 (rev 1039): Keine Patches
IOS22 (rev 1294): Keine Patches
IOS28 (rev 1807): Keine Patches
IOS30[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS31 (rev 3608): Keine Patches
IOS33 (rev 3608): Keine Patches
IOS34 (rev 3608): Keine Patches
IOS35 (rev 3608): Keine Patches
IOS36 (rev 3608, Info: rev 3351): Trucha Bug, ES Identify, NAND Zugriff
IOS37 (rev 5663): Keine Patches
IOS38 (rev 4124): Keine Patches
IOS40[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS41 (rev 3607): Keine Patches
IOS43 (rev 3607): Keine Patches
IOS45 (rev 3607): Keine Patches
IOS46 (rev 3607): Keine Patches
IOS48 (rev 4124): Keine Patches
IOS50[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS51 (rev 4864): Funktionslos (Stub)
IOS52 (rev 5888): Funktionslos (Stub)
IOS53 (rev 5663): Keine Patches
IOS55 (rev 5663): Keine Patches
IOS56 (rev 5662): Keine Patches
IOS57 (rev 5919): Keine Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 65535, Info: rev 6174): Trucha Bug
IOS61 (rev 5662): Keine Patches
IOS70[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS80[60] (rev 65535, Info: rev 6174): Trucha Bug
IOS90 (rev 65535): Trucha Bug
IOS202[60] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Zugriff, USB 2.0
IOS222[38] (rev 65535, Info: hermes-v5.1): Trucha Bug, ES Identify, NAND Zugriff, USB 2.0
IOS223[37] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Zugriff, USB 2.0
IOS224[57] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Zugriff, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Zugriff
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Zugriff, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Zugriff
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Zugriff, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Zugriff, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Zugriff, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Zugriff, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Zugriff, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Bericht wurde am 18.12.2007 generiert.
Update:
Today I tried USB Loader GX with the Option of USB Port 1, but my problems are still there. No USB Drive is detected.Last edited by dolly0190; 15 October, 2012, 13:00.Comment
sysCheck v2.1.0b18 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: NTSC-U
System Menu 4.3U (v513)
Priiloader installed
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS58
Hollywood v0x11
Console ID: 63522751
Boot2 v4
Found 91 titles.
Found 53 IOS on this console. 4 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
BC v6
MIOS v10
Report generated on 2012/10/17.
sysCheck #z7YWjNEfComment
Region: PAL
System Menu 4.1E (v450)
Drive date: Unknown
Hollywood v0x21
Boot2 v4
Found 85 titles.
Found 55 IOS on this console. 6 of them are stub.
IOS3 (rev 65280): Stub
IOS9 (rev 54321): Trucha Bug
IOS11 (rev 54321): Trucha Bug
IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS20 (rev 54321): Trucha Bug
IOS30 (rev 54321): Trucha Bug
IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
IOS40 (rev 3072): Stub
IOS50 (rev 54321): Trucha Bug
IOS52 (rev 5888): Stub
IOS60 (rev 54321): Trucha Bug
IOS70 (rev 54321): Trucha Bug
IOS80 (rev 54321): Trucha Bug
IOS90 (rev 54321): Trucha Bug
IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v65535
Report generated on 2012/24/10.Comment
If you have some time pls check my sys check above. I have downloaded your zip file followed your instruction guide inside and still cant find hdd. Just so you know the port closest to the end wont start the Hdd (light on hdd) but when i put it on the inside at least it can start it but the usb loader cant read it. ANY HELP WELCOME. I have been on this for 2 weeks now. Due to the fact that my wife wants to see some TV.Comment
Thats sysCheck doesn't look to bad. Your IOS236 is an older number this is important for installing cIOS wads. What you could do is run ModMii from Windows and use the SU option then type in the location of your sysCheck.csv file. That will check for any updates, and add them into a COPY_TO_SD sub folder. It will add [IOS236-v5-Mod] folder to the apps folder that should install the newer IOS236, the IOS36 needs to be on the root of the SD card. Install that first from Homebrew.
You're also using d2x v.70 you may as well add the d2x v8 Final wad pack
ModMii will only adds 2 d2x v8.0 wads cIOS249 and cIOS250 so you may as well install all those d2x v8.0 wads.
I'm not saying this will make your HDD be recognised but there is nothing you can do wad wise to make it work. Its down to is the drive compatible and how you have the games loaded onto it.Keith
try to install WiiFlow carbon forwarder channel with no sd card inserted because i have tried different brands o hdd using fat32 or wfbs format and it works fine just make sure that you have pointed your wii to ios249 or 222 it depends on the game and usb port bottom oneComment
Are you suggesting that he installs a forwarder channel to run his games from with no further info about what loader to install into what folder on what device and that he will be able to run a wbfs formatted drive with just a forwarder channel and no sd card installed to store apps on...............Have you ever seen my post to newbies that states there is no such thing as stupid questions just stupid answers and I have just pointed out how stupid some answers are on your last two posts. Please bear in mind people come here for help and the wrong info is much worse than no info and is the fastest way to cause inexperienced users to brick their consoleComment
