usb loader cant find HD
  • docj0nes
    • Nov 2014
    #241
    Could anyone suggest a solid tutorial on modding the wii? I'm using the one from WiiHacks.com but as I'm experiencing issues maybe I should run through another to be sure it's not the package they supply. Other than that it looks like I need to source another HDD to rule out the drive itself. As mentioned before though - I doubt its hardware since it runs fine outside of USB launchers.
    • Keithuk
      • Aug 2010
      • 2264
      #242
      There are loads of softmodding tutorials on here it depends on your Wii version number.
      Keith
      2010 Golf GTD (170)
      • Jimson
        • Dec 2014
        #243
        Originally posted by happy_highlander
        Without a syscheck report we can't tell you if anything is missing as we don't know which softmod method was used. Have you tried installing wiiflow or cfg to see if they recognize the hdd. Did you say your wii recognizes his hdd or is it his wii that recognizes your hdd, try your hdd on his wii
        Hello,
        I have a similar problem
        This is my syscheck
        Can you help me please?
        sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
        ...runs on IOS36 (rev 3608).
        Region: PAL
        System Menu 4.3E (v514)
        Could not detect the drive date!
        Homebrewk**** ist nicht installiert
        HomebrewFilter ist nicht installiert
        Hollywood v0x11
        Console ID: 89375190
        Boot2 v4
        Found 76 titles.
        Found 38 IOS on this console. 10 of them are stub.
        IOS3 (rev 65280): Stub
        IOS4 (rev 65280): Stub
        IOS9 (rev 1034): Trucha Bug, ES Identify, NAND Access
        IOS10 (rev 768): Stub
        IOS11 (rev 256): Stub
        IOS12 (rev 525): Trucha Bug, ES Identify, NAND Access
        IOS13 (rev 1031): Trucha Bug, ES Identify, NAND Access
        IOS14 (rev 1031): Trucha Bug, ES Identify, NAND Access
        IOS15 (rev 1031): Trucha Bug, ES Identify, NAND Access
        IOS16 (rev 512): Stub
        IOS17 (rev 1031): Trucha Bug, ES Identify, NAND Access
        IOS20 (rev 256): Stub
        IOS21 (rev 1038): Trucha Bug, ES Identify, NAND Access
        IOS22 (rev 1293): Trucha Bug, ES Identify, NAND Access
        IOS28 (rev 1806): Trucha Bug, ES Identify, NAND Access
        IOS30 (rev 2816): Stub
        IOS31 (rev 3607): Trucha Bug, ES Identify, NAND Access
        IOS33 (rev 3607): Trucha Bug, ES Identify, NAND Access
        IOS34 (rev 3607): Trucha Bug, ES Identify, NAND Access
        IOS35 (rev 3607): Trucha Bug, ES Identify, NAND Access
        IOS36 (rev 3608): Trucha Bug, ES Identify, NAND Access
        IOS37 (rev 5662): Trucha Bug
        IOS38 (rev 4123): Trucha Bug, ES Identify, NAND Access
        IOS50 (rev 5120): Stub
        IOS51 (rev 4864): Stub
        IOS53 (rev 5662): Trucha Bug
        IOS55 (rev 5406): Trucha Bug
        IOS56 (rev 5661): Trucha Bug
        IOS57 (rev 5918): Trucha Bug
        IOS58 (rev 6175): USB 2.0
        IOS60 (rev 6400): Stub
        IOS61 (rev 5661): Trucha Bug
        IOS70 (rev 6687): Trucha Bug
        IOS80 (rev 6943): Trucha Bug
        IOS236[58] (rev 21, Info: rev 21): Trucha Bug, NAND Access, USB 2.0
        IOS249[57] (rev 21, Info: rev 21): Trucha Bug, NAND Access, USB 2.0
        IOS250 (rev 65535): Trucha Bug, NAND Access, USB 2.0
        IOS254 (rev 65281): BootMii
        BC v6
        MIOS v10
        Report generated on 2014/12/28.
        Best regards
        Jim
        • Jimson
          • Dec 2014
          #244
          Originally posted by Jimson
          Hello,
          This is my syscheck
          Region: PAL
          Hollywood v0x11
          Boot2 v4
          Found 76 titles.
          BC v6
          MIOS v10
          Best regards
          Jim
          I got it working with this tut
          IOS249 - GAF's Wii Homebrew Tutorial
          • Keithuk
            • Aug 2010
            • 2264
            #245
            So are games now working of a USB hard drive?
            Well that first sysCheck you have 10 IOS's that are Stub but you have installed IOS 12, 13, 14, 15 I don't know how. You need to remove IOS 11, 20, 30, 50 install 40.
            You do have IOS36 and IOS236 that's all but you need to reduce that 10 down to 4 or 5.
            Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
            ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
            Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
            Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
            Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
            If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
            Do another sysCheck to make sure everything installed correctly and post that.
            Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
            Keith
            2010 Golf GTD (170)
            • turbointel
              • Dec 2014
              i just wanted to say thanks as followed the info above as had same problem my hdd would not load games and this worked like a charm and im up and running so thanks again for the info
              • DozeBeatS
                • Jan 2015
                • 4
                #247
                Hey guys, total noob here. I recently installed the homebrew channel on my Wii U along with USB Loader. When I turn my console on, the drive is detected by the Wii, but when I run USBLoader it does not detect the drive. The drive I am using is an HDD with a powered enclosure. I loaded Syscheck so I can get a log and possibly some help. If anyone has the time to help me out, I'd appreciate it. Let me know what other info you may need from me.
                Thanks in advance.
                Here is the log...
                ...runs on IOS58 (rev 6432).
                Region: unknown
                System Menu 4.3 (v609)
                Drive date: 2011.06.28
                Homebrew Channel 1.1.2 running on IOS58
                Hollywood v0x21
                Console ID: 611420505
                Boot2 v0
                Found 45 titles.
                Found 34 IOS on this console. 0 of them are stub.
                IOS9 (rev 1290): No Patches
                IOS12 (rev 782): No Patches
                IOS13 (rev 1288): No Patches
                IOS14 (rev 1288): No Patches
                IOS15 (rev 1288): No Patches
                IOS17 (rev 1288): No Patches
                IOS21 (rev 1295): No Patches
                IOS22 (rev 1550): No Patches
                IOS28 (rev 2063): No Patches
                IOS31 (rev 3864): No Patches
                IOS33 (rev 3864): No Patches
                IOS34 (rev 3864): No Patches
                IOS35 (rev 3864): No Patches
                IOS36 (rev 3864): No Patches
                IOS37 (rev 5919): No Patches
                IOS38 (rev 4380): No Patches
                IOS41 (rev 3863): No Patches
                IOS43 (rev 3863): No Patches
                IOS45 (rev 3863): No Patches
                IOS46 (rev 3863): No Patches
                IOS48 (rev 4380): No Patches
                IOS53 (rev 5919): No Patches
                IOS55 (rev 5919): No Patches
                IOS56 (rev 5918): No Patches
                IOS57 (rev 6175): No Patches
                IOS58 (rev 6432): USB 2.0
                IOS59 (rev 9249): No Patches
                IOS62 (rev 6942): No Patches
                IOS80 (rev 7200): No Patches
                IOS1768489209[56] (rev 21010, Info: d2x-v10beta53-alt-vWii): No Patches
                IOS1768489210[57] (rev 21010, Info: d2x-v10beta53-alt-vWii): No Patches
                IOS1768489211[58] (rev 21010, Info: d2x-v10beta53-alt-vWii): No Patches
                IOS512 (rev 7): No Patches
                IOS513 (rev 1): No Patches
                Report generated on 2015/01/12.
                • Keithuk
                  • Aug 2010
                  • 2264
                  #248
                  Well I don't deal with Wii U so all I can say is do what I've suggested to other as you have no Stubs but everything is No Patches.
                  Keith
                  2010 Golf GTD (170)
                  • DozeBeatS
                    • Jan 2015
                    • 4
                    #249
                    Ok I tried what you suggested, and this is my result.
                    • Keithuk
                      • Aug 2010
                      • 2264
                      #250
                      Well if you tried everything I've said which works on a normal Wii then I can't really help you with your Wii U.
                      Keith
                      2010 Golf GTD (170)
                      • DozeBeatS
                        • Jan 2015
                        • 4
                        #251
                        Thanks anyway man, I appreciate it.
                        • DozeBeatS
                          • Jan 2015
                          • 4
                          #252
                          Ok I actually got it to work. Can you tell me how to make my games play in full screen? Right now I have the black lines on each side.
                          • happy_highlander
                            • Aug 2010
                            • 3535
                            #253
                            Sounds like you are set to ntsc instead of pal.
