Wii USB HD Loader
  • ck-ok
    • 2592
    #481
    yes you can
    • johnboy003
      • 12
      #482
      Wopks fantastic, got all the cover images and disc images, and out of 60 odd games i only need the disc in with splinter cell and medal of honour sometimes, nice job
      • kingdm9
        • Aug 2010
        #483
        what is the largest hdd the wii supports will it do 2tb?
        does it like certain hdd ?
        • CarlosLeiras
          • Aug 2010
          Neogamma issues
          I tried several versions of neogamma and none works, when i start the program the screen turns into black. Should I try the usb loader or there is a solution for the neogamma problem? thanks [[]]
          • ck-ok
            • 2592
            #485
            it could be that you have a new type dvd drive that cant be modded,type in your serial number on the net to find out.if you have then usb will be your best option
            • mr-mixalot
              • 7
              #486
              Excellent guide
              However my drive just died last week before I could backup any games, can I just create ISO files of the games using my laptop drive / software and use these instead on the Loader
              • ck-ok
                • 2592
                #487
                Originally posted by mr-mixalot
                Excellent guide
                doubt it theres only a couple of drives that can read wii discs,try a lens cleaner and see if you can get your old drive working
                • mr-mixalot
                  • 7
                  #488
                  Tried that but it didn't work
                  Anyway sussed a workaround if its of help to anyone
                  Used Alcohol 120% to create image of game (4.37GB) using my laptop BluRay drive, then I used WBFS Manager to just extract the game part from the image and move this to my HDD
                  Tried it last night and it worked, image of Carnival games was 4.37GB, WBFS Manager then extracted the 1.17GB game image off and put this on my USB drive, hooked this up to my Wii, loaded up WiiFlow and it worked a treat
                  • ck-ok
                    • 2592
                    #489
                    did you make the backup from an original or a previously backedup disc?
                    • bigb123
                      #490
                      i get a blank screen and wii remote flashes
                      • bigb123
                        #491
                        the usb loader and cios doesnt show on the homebrew channel ive extracted to the root of the sd card like u sed sorry im dumb
                        • mr-mixalot
                          • 7
                          #492
                          I made a backup of a previously backedup disc
                          Done about 65 now and all seem to work
                          • ck-ok
                            • 2592
                            #493
                            sorry got confused thought you wanted to make a backup of an original disc,which you will struggle with using a pc drive,but any drive will make a backup of previously backedup disc,as you now know.
                            • hevi
                              • May 2010
                              • 18
                              #494
                              i have usb loader 4,6 and works ok.
                              do i need to update to this one?
                              • Atsuktuvas
                                • Apr 2010
                                • 7
                                #495
                                Does it work on 4.0?
