This soft mod is for V4 and uses the bannerbomb crack upgrading to V4 is not recommended(only by me) this has been tested on V4 and works but this is a little more detailed than the Soft mod for dummies in the sense that if the aad1f_v108 file does not work you have to go to the site (link supplied) and get a different version other than that its fairly ok. Follow the tut in the doc. file exactly and you should be fine. This is for versions 4 wii's. Please do not use this thread for first post, the thread is to help those that need help and advice
New members please read here first http://www.digital-kaos.co.uk/forums...-posting-1129/
HI all, newbie here. I have a chipped wii and Have just put new super mario bros in not relising it was ntsc version and not pal, think i have now semi-bricked my wii as i cant access the wii menu settings.
the game updated my wii when i put it in so will this have updated it to version 4.1 or 4.2 and if so if i do a v4 wii softmod and then put super mario bros pal game in will this rectify the problem?
Can any one help? I downloaded the programme and copied the install.bat file to sd card after formatting it but when I try to install to the Wii,I get this message.What am I doing wrong?
CIOS249 not found.You need ios16-64-v257 prod.wad and cios249.wad.
Thanks.
Thanks.
Try the tutorial I posted up yesterday m8, might be a bit easier for you to get it working.
HTH
