V4 Wii Softmod (without zelda)
hi i updated my wii to the version 4.1e and followed the guide step by step here is a helpful link [Guide] Fully Softmod Any Wii (everything you need) - GBAtemp.net
on the section cIOS38_rev13a: You have 2 options on how to install the cIOS
i connected to wifi and used option b) Network Installation: (Recommended)
as i got an error the first time also they is a new cIOS38_rev14
you should beable to get these on the link but if not an you are still struggling let me know and i will try to help the best i can .Comment
Only problem in the pakage for dummies is I can't downgrade it and install the cIOS. I have heard that somedody mixed two pakages together, but this is too high level for mehi i updated my wii to the version 4.1e and followed the guide step by step here is a helpful link [Guide] Fully Softmod Any Wii (everything you need) - GBAtemp.net
hi nizinsky you need to followed the guide step by step
1) Downgrade IOS35:
This section will downgrade and patch IOS35 so we can install a cIOS.
Start the Homebrew Channel and run DowngradeIOS35 from the Homebrew channel menu.
Go up and select "Downgrade IOS35" (skip patchmii and dvdx).
After it downgrades IOS35 go down to "EXIT" and it should exit to the Homebrew Channel.
Run WAD Manager.
Select A to agree to the disclaimer.
Select IOS version to use: <IOS35> Press A.
Select source device: <Wii SD Slot> Press A.
Go to IOS35.WAD in the list and press A.
Select action: <install wad> press A.
After the WAD file is installed press HOME to return to the Wii System menu
download Trucha Bug Restorer and Watch video.
will need to be pacthed on newer Wiis, but it won't hurt to do it on all Wiis, so I'll just put the steps here anyway. If you think you don't need it, you can skip this-- but if the next steps don't work, come back here. =)
Things you'll need:
1) SD card with a folder called apps on its root.
2) Trucha Bug Restorer.
3) If your Wii does not have internet, you will need to create the necessary wad files on the root of your SD (these are merely the files your Wii would normally download if it has an internet connection. Create them here!
Steps:
?Extract the files from the downloaded Trucha Bug Restorer zip.
?Copy the TBR folder to the apps folder on your SD card.
?Start HBC
?Load TBR
?Use IOS 36 to downgrade 15. << Watch Video. See note if you don't have a network connection!
?Use 15 to patch 36. << Watch video. See note if you don't have a network connection!
?And use 36 to restore 15. << Watch video. See note if you don't have a network connection!
Video: [ame="http://www.youtube.com/watch?v=ltrd3oq8hPc"]YouTube - Det1re's "How To use Trucha Bug Restorer (TBR)"[/ame]
Now that you have patched IOS 36, you can install newer cIOS and PreLoader.
Note: If you do not have a network connection, select wad installation where the video says network install. The files you created earlier will need to be on the root of your SD card.
cIOS38_rev14: download cIOS38 rev14 cIOS38_rev14 in place of cIOS38_rev13a & i used options b) Network Installation: At the instillation option screen press RIGHT 1 time on the D-pad of the Wiimote. This will download the files via WiFi.
cMIOS: to install the cMIOS files i also used options b) Network Installation:Comment
[QUOTE=micky06;258941]hi nizinsky you need to followed the guide step by step
Thank you for the instruction. I've forgot to tell you that I only tried to download full pack for dummies and stuck on ref- 1035 error. And than leater I didn't download anything so means I have not homebrow channel installed . I thing only dont't know if I should format my wii now before will start with it?? Realy interesting me to play burned games on wii. So what I should to do before will start instruction which you gave me??Marcin
I've just found something like that:http://randomualrstudent.wordpress.c...modding-guide/
What do you thing about it???Last edited by nizinsky; 20 August, 2009, 10:14.Comment
Thank you.
Have 2 wiis (dont ask why, please). One with 4.0, which I successfully softmodded one with 3.4U, which I will try this softmod on.
For those with 002 error, disable wiiconnect, and make sure you scrubb the DVDs before you burn them, Google "Error 002 Fix", and download files, its fairly simple to do.Comment
is there any way to reset the wii and re patch it?This soft mod is for V4 and uses the bannerbomb crack upgrading to V4 is not recommended(only by me) this has been tested on V4 and works but this is a little more detailed than the Soft mod for dummies in the sense that if the aad1f_v108 file does not work you have to go to the site (link supplied) and get a different version other than that its fairly ok. Follow the tut in the doc. file exactly and you should be fine. This is for versions 4 wii'sComment
guide worked fine on a v4.1 wii , it has installed the back up installer etc , also used the dummies one for a 3.4 wii
only prob now is the 3.4 wii plays the games the 4.1 doesnt just stuggles to read the disc , do you think this is console related or is there something missing ,
thanksComment
