Wii 4.2E softmod tutorial. Easy to follow guide.
  • ck-ok
    • 2592
    #511
    Originally posted by reca313
    does this work on 4.2U and if i format my wii hard drive will it give me a clean start??
    yes this will work for you,and no you dont need to format your wii
    • short360uk
      • 313
      #512
      like ck says there is no need to format ur wii this only removes game saves it doesnt do anything to system files
      • EricLiu
        • Apr 2010
        • 14
        #513
        I need to format SD card as FAT (standard) wich is FAT16 and not FAT32... but what is the difference.. what if I did it with FAT32?
        • ck-ok
          • 2592
          #514
          fat 32 is ok
          • EricLiu
            • Apr 2010
            • 14
            #515
            ok but is FAT16 also ok, I thought need to do with FAT 16 so I formatted it >FAT16
            Thanks.
            • ck-ok
              • 2592
              #516
              Thanks.
              yes fat 16 is ok also
              • EricLiu
                • Apr 2010
                • 14
                #517
                But I formatted > FAT16 now, does it matter?
                • ck-ok
                  • 2592
                  #518
                  no just carry on
                  • EricLiu
                    • Apr 2010
                    • 14
                    #519
                    I have succesfully installed priiloader on the wii, but I don't see the button for launch bootmii??
                    • ck-ok
                      • 2592
                      #520
                      when your on the homebrew chanall push the home button
                      • EricLiu
                        • Apr 2010
                        • 14
                        #521
                        I can't launch bootmii, but I have the bootmii files, how come??!!
                        Anyone please help...
                        • short360uk
                          • 313
                          #522
                          is bootmii installed as ios, or boot2. go to homebrew channel press the home button as ck says, launch bootmii should be listed, or if installed as boot2 it should auto launch when the wii is powered up if the bootmii folder is on sd card
                          • EricLiu
                            • Apr 2010
                            • 14
                            #523
                            funny thing is, nothing is listed... I only see:
                            Back
                            About
                            Exit to System Menu
                            Shutdown
                            • short360uk
                              • 313
                              #524
                              ok mate then it must installed as boot2 or not installed at all. put ur bootmii files on the root of ur sd then power up ur wii, it should auto load
                              • EricLiu
                                • Apr 2010
                                • 14
                                #525
                                It's installed, I reinstalled bootmii, put sd card back in computer and I can see the map bootmii with the necessary files.. but it doesnt show on homebreww and also nothing when I press home button..
                                Its installed as bootmii ios, I can't install it as boot2
