Wii 4.2E softmod tutorial. Easy to follow guide.
Thanks again CK
Still unsure of this though...
I checked back through my original installation of hbc and had missed some bits out (doh) so I reinstalled it and gained a seperate u loader channel.
After reading through the directed post i came to the conlusion i did not have priloader on and it did not come with the hbc pack?
So i got an independent copy from ades reference to the completesoftmod guide(as his are not there?) I followed instuctions to put that one on & evrything goes fine.
I now have two u loaders I can use to boot up my discs but I am still mostly concerned about pressing the original wii disc channel where an update awaits with a warning message,do i update or not?(cant find a reference to this) I have been unable to make a nandbackup as nothing happens when I press 'home' on the hb channel there is a messsage at the top left though'system is not initilialized' which afterwards changes to the wii ip address.
Thanks for your prompt replies so far...
What to do next
please???
edit~just read a further doc in guide & it looks to me bootmi should of installed along with the bannerbomb file?
If ive buggered up along the way can I go back and start afresh?
God im tired and confused, off for sleeps.Last edited by slartiluck69; 15 May, 2010, 01:58.Comment
go right back to the first section and install bootmii and dvdx if you havn't already,once thats installed when you push the home button you will be able to make a nand backup,not all updates are system updates some are just iso's a game needs to run if your on 4.2 let it update,as for 2 uloaders,if you want to delete one use wad manager and uninstall one of the uloader forwarder wadsThanks again CK
What to do next
please???
God im tired and confused, off for sleeps.sigpicComment
Hey, I have 4.2e firmware and I installed everything in the first post and I got it working, kinda.
USB works with PAL, I belive PAL is for my Europe and NTSC is for America? Cuz only PAL work.
Anyways, I cant load burned dvd. I get DVD Error -2
I am using DVD-r or -rw which shouldnt make and diffrence.
And also I cant watch movies, same error in original and burned.
I have looked at a lot of these post but cant really find anything to help me.
Can you please help me fix so I can use Burned DVD Games, watch Movies and burned movies?Comment
if you brought the wii recently it could have the new chip which stops you playing dvd-r's for playing movies read this http://www.digital-kaos.co.uk/forums...49/#post474411Hey, I have 4.2e firmware and I installed everything in the first post and I got it working, kinda.
Can you please help me fix so I can use Burned DVD Games, watch Movies and burned movies?sigpicComment
I bought it before christmas last year I belive.if you brought the wii recently it could have the new chip which stops you playing dvd-r's for playing movies read this http://www.digital-kaos.co.uk/forums...49/#post474411
And btw I have only followed the instructions on the first post.
And its very confusing lookin through all the posts.
So my question still remain.
Last post
ok your wii wont have one of the new chips,make sure you installed dvdx from first post,use verbatim dvd-r's not -rw and use imgburn on x4 speed,to play ntsc make sure you select force ntsc in loader settings,to watch movies you will need a multi media player installed like the one from my previous postI bought it before christmas last year I belive.
Last post
I've heard as long its -r or -rw It should work. Ive checked many youtube videos and stuff.ok your wii wont have one of the new chips,make sure you installed dvdx from first post,use verbatim dvd-r's not -rw and use imgburn on x4 speed,to play ntsc make sure you select force ntsc in loader settings,to watch movies you will need a multi media player installed like the one from my previous post
And I dont evan know about "verbatim dvd-r"
What loader settings are we talking about? Uloader Home?
Im gonna try what you said and look for your previous post ty.
Ill post again if its more problems
ty guys bigtimeComment
forget about you tube videos,google verbatim dvd-r most places sell them,and yes uloader homeI've heard as long its -r or -rw It should work. Ive checked many youtube videos and stuff.
ty guys bigtimesigpicComment
Hi me again
Went back and started the first bit as advised(I guess from installing bannerbomb?) and i now get the message 'Neither /boot.dol /boot.elf could be found.I have tried this on the original SD card and a new 1.
So I am still unable to do a back up ???
HelpComment
U must put boot.dol or elf in the root in your SDHi me again
Help
and really doesnt matter if you open SD card from Wii Icon Data managment or the SD card from the Wii channels in the beginning.
Read the instructions carefully and you will get it right
Atm i cant get the Verbatim dvd-r, but ill try make it work with DVD films. If that works, then it should work with burned games to yea?
can you plz link the post to the multi media thread/post?Last edited by Cornholio; 17 May, 2010, 22:12.Comment
not forced to movies and games are different,movies tend to work on cheaper media,but at least you will know you'll know you can play backupssigpicComment
Hi CK
Reference above post...Can I get rid of homebrew channel etc & start again?
Its twistin me melon man
CheersComment
