Wii 4.2E softmod tutorial. Easy to follow guide.
  • petrocles
    #271
    7. In the Homebrew Channel Run WAD Manager.
    When it opens choose IOS36, Press A to open from SD slot. Install the following WAD files as listed below to your Wii:
    cIOS202[38+60]-v4.wad
    cIOS222[38]-v4.wad
    cIOS223[38+37]-v4.wad
    IOS249-v14.wad
    cIOS250-v14.wad
    IOS70-64-v6687[TB+ES_diV+NAND].wad
    forwarder-UMRD wad
    You are now set for playing backups on your Wii.
    i have been able to download all e`xcept
    cIOS202[38+60]-v4.wad . is this going to cause problems? ERROR ! (ret = -1022)
    • M_N_M
      • 9
      #272
      Originally posted by tobb3
      anybody else having trouble playing mario kart with this softmod? (using backup cd's)
      says it cant read the disc...hmzz
      works great over here (but I play from USB, not from DVD)
      • M_N_M
        • 9
        #273
        Originally posted by Raccoon
        Hello!
        I?m a total newbie, haven?t even got my Wii yet.
        What I wonder is if you can still play originals as easy as before moding?
        yes, same way to play original games as before modding.
        • Raccoon
          • 25
          #274
          Thank you, thats all i needed to know. Then the kids will still manage on their own.
          Unfortunately my Wii won?t show up until about 2 weeks from now.
          Is there any screendumps of the moded Wii to check out anywhere? Like menus or something.
          • Scampie
            Hi. Im new here and just looking for a bit of advise. Im modding my sons Wii and so bricking it could be pricey It seems you need to keep your Wii connected to the internet for this. Is there anything on the wii to do with internet connection which i need to turn off in order to prevent bricking? Automatic updates etc? What is it exactly that causes your wii to brick?
            Thanks in advance.
            • krs
              #276
              Hi, Im having problem with this install on my Wii. I installed it just fine on my parents, so decided to home and do mine. I get up to loading anytitle deleter to remove the certain sections and the Wii freezes and the wiimote disconnects. I have to physically remove the power cable at the back to restart it. My console is currently on 4.2e. Cheers
              • dell_xps
                • 2558
                #277
                Just carry on from where it crashed m8,try the next ios.
                HTH
                • dell_xps
                  • 2558
                  #278
                  Thanks in advance.
                  Hi m8 you only have to have wifi turned on if your installing cIOS 15 from network installation, cIOS 14 is incorporated into the download files now, so no net access is needed for cIOS 14 ok.
                  • krs
                    #279
                    HTH
                    It won't even let me select an IOS, as soon as it hits the first screen it freezes
                    • dell_xps
                      • 2558
                      #280
                      Formatt the memory stick, put the files back on, make sure the lock on the sd card is not on, try again.
                      • krs
                        #281
                        Cheers, have done a few different things so went back to the beginning and did your process again using the memory card formatted to FAT not FAT32 and it worked.
                        • dell_xps
                          • 2558
                          #282
                          No probs m8, glad you got it working.
                          • johsm67
                            Stupid Quiestion maybe, but are old GC iso's possible to use also on a soft modded box.....
                            • dell_xps
                              • 2558
                              #284
                              Yes with cIOS rev 14, 15 dont work I'm led to believe m8.
                              • frodo60
                                Thank you for this information. It has been of great use to me.
