Update Softmodded wii from 4.0E to 4.2E
  • lollable
    • Nov 2010
    I currently have version 4.0E. Should I first upgrade to version 4.2E using the v4.2 safe firmware updater and then do the softmod?
    • ck-ok
      • 2592
      #32
      yes you can do that or use modmii to softmod it,and when asked if you'd like to update to 4.1 click yes,as thats one of the best firmwares to be on.
      • fox67
        • Nov 2010
        • 4
        #33
        http://www.digital-kaos.co.uk/forums...indows-170234/
        Hi!
        I think I got what I need now to mod my Wii
        Thanks for a excellent thread
        • ck-ok
          • 2592
          #34
          Originally posted by fox67
          Hi!
          let us know how you go on
          • fox67
            • Nov 2010
            • 4
            #35
            Looks like its working. Everything seemes like before but now it says 4.2E. I have a original game "Just Dance" it didnt work before and it doesnt now. It says " In order to use this software, you must perform a Wii system update. Select OK to begin the update." I havent done that. Is it safe to do that? Getting New Super Mario Bros. Will test that tomorrow. Last I tried that the TV went green. Thanks for a great site.
            • ck-ok
              • 2592
              #36
              which tut did you follow and have you installed preloader?
              as for nsmb try forcing the region in loader settings sounds like its a different region
              • fox67
                • Nov 2010
                • 4
                #37
                I followed a guide on Wiihacks.com last year it was a long complicated guide do you think i should unmod it and then mod it again?
                • ck-ok
                  • 2592
                  #38
                  there should be no need to mod it again,but if you want to then you can just mod over the old one it wont cause any harm,because you already have the homebrew channel installed all you would need to do is install from step 1 of this tut http://www.digital-kaos.co.uk/forums...w-guide-67927/
                  • fox67
                    • Nov 2010
                    • 4
                    #39
                    ok ill try that
                    • pezza30
                      • Dec 2010
                      4.1e
                      will the updater to 4.2e work on a 4.1e wii??
                      • reddevil157
                        • 1427
                        #41
                        Why do you wanna update ?
                        • grassgrass
                          • 9
                          #42
                          Hi to all i have tryed to update my wii which is ver 3.2e softmod to 4.2 with v4.2 safe firmware updater and right at the end it fails to update will it not update from 3.2 gratefull for reply
                          • reddevil157
                            • 1427
                            #43
                            To update your old sofmod, take a read of this. Or if you got an original copy NSMB, stick it in the wii, accept the update, will put you on 4.1, do the 4.1 softmod.
                            • grassgrass
                              • 9
                              #44
                              thanks reddevil157 i will have alook and get back to you thank for reply
                              • loebasje
                                • Dec 2010
                                softmod to 4.3E
                                Is there also a soft updater to the last version ?
                                What benefits has the upgrade to 4.3E ?
