Update Softmodded wii from 4.0E to 4.2E
  • reddevil157
    • 1427
    #46
    Originally posted by loebasje
    Is there also a soft updater to the last version ?
    What benefits has the upgrade to 4.3E ?
    What system menu are you on now?
    • smurgy
      • Dec 2010
      smurgy
      how can i update from 4.0e to 4.2e .. cant instal wads through wad manager for neo gamma .. any help would be appreciated
      • jeroenpads
        • Dec 2010
        Originally posted by short360uk
        put this in ur apps folder on sd card and run from homebrew channel v4.2 safe firmware updater
        I hope this will work for me also. I'll try it and let you guys know.
        Best regards,
        Jeroenpads
        • Zzzlain
          #49
          Does the updater still work for older versions? I mean like 3.4 for example.
          • ck-ok
            • 2592
            #50
            yes it does
            your first post should be in the introduction section
            • Zzzlain
              #51
              Hello again
              I'm a total noob at this softmoding thing so i got it all wrong. I had a 3.9 softmoded wii and i got an original guitar hero 6 disc so when it asked for an update in order to play the game i said yes and it updated to version 4.2e and only after doing that i used "v4.2 safe firmware updater" which i think was pointless. So everything is messed up: Neogama doesnt work and configurable usb loader freezes at the starting screen.
              Is there any possible solution to solve this or should i remove everything and do the whole softmoding thing again for 4.2e? Thanks in advance!
              • ck-ok
                • 2592
                #52
                Hello again
                just do it all again with 4.2
                • markschuring
                  • Aug 2009
                  #53
                  Gonig to try the firmware upgrade right now, i'm on 4.0E with a softmod. due to 002 errors trying this upgrade. will let you know what the outcome will be
                  • reddevil157
                    • 1427
                    #54
                    There's a 002 fix in the usb loaders.
                    • markschuring
                      • Aug 2009
                      #55
                      all working fine now!, firmware is on 4.2E now. Took about 30 minutes to complete.
                      • markschuring
                        • Aug 2009
                        #56
                        Thanks verry much!, i also did a new usb loader install (Cfg_USB_loader62) and no more 002 errors
                        • killa aka ruffrida
                          #57
                          thanks a lot i have been searching every where for this! hope it works as I have been waiting to play the new call of duty!
                          • dvreezen
                            #58
                            • swfcowl5
                              brillaint thanks for that
                              • spareman
                                • Feb 2011
                                • 5
                                #60
                                helped alot. thank you so much for this.
