4.3 mod
  • joyjas77
    • Dec 2011
    I have a 4.3E Wii that I used LetterBomb to softmod. Being my first time modding, it was quite easy to get Homebrew Channel and BootMii on the unit. From there it has been a little tricky. I had basically a virgin console. Pulled out of the box, turned on and then softmod.
    I was able to install the Trucha Bug after a bit of playing around.
    I have been unable to get any of the WAD's to install using Multi-Mod Manager. I have tried a couple of different downloads of Multi-Mod Manager all to no avail.
    I have also tried to install waninkoko's cIOS 249 and 250 using the latest version (cIOSX rev21). I found that I was unable to use the Wiimote to press A to finish install so I tried earlier versions and this was the same situation. I see others had this problem and it was suggested to use pimp_my_wii which I did unfortunately this didn't help.
    I've been googling over and over but can't seem to find a method that works.
    I have a copy of sysCheck output if that helps.
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priilaoder installed
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x21
    Console ID: 156823050
    Boot2 v4
    Found 69 titles.
    Found 46 IOS on this console. 17 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): Trucha Bug ES Identify NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS249 (rev 65280): Stub
    IOS250 (rev 65280): Stub
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2011/12/23.
    Any help would be appreciated. I've probably tried other things but done so much now can't remember it all.
    • mrh2003
      • Dec 2011
      Hi..
      Bought a US game for an Euro console by mistake...
      • Keithuk
        • 2264
        #228
        Welcome to the forum.
        Well if you have USB Loader GX you can insert the disc and click the + button to install it onto the HDD and play it from there. USB Loaders will play PAL and NTSC games just the same.
        Keith
        2010 Golf GTD (170)
        • largsone
          • Dec 2011
          Homebrew Works with this
          I found that Homebrew works following these steps but I have found Softmodding more difficult. Not very technically minded. Can anyone recommend a simple step-by-step method to do this for 4.3e
          • Keithuk
            • 2264
            #230
            If you have a 4.3E then the cheapest method will be LetterBomb that will only softmod and nothing else. If you going to use an powered external hard drive then you should follow the USB Loader tutorials on here?
            Keith
            2010 Golf GTD (170)
            • vaugloo
              • Dec 2011
              #231
              Gone a little off course in modding wii
              Hi guys, got lost in the sea of advice iro wii 4.3 modding on the internet. I tried the letterbomb & managed to get homebrew channel on wii - however how do I play my copied discs? There is no neogamma etc.
              Then tried indiana jones method (paid an extortionate price for one of e-bay). Keeps giving me the same error on trying to load IOS236 (-1035 error)
              Anyone got an ideas? completely lost iro where to go now & unlpugged / plugged power back in around 40 times as keeps going to black screen when accessing MMM etc.
              Please can someone give me an idea of how to resolve this easliy (I am on 4.3E)
              Vaughan
              • Keithuk
                • 2264
                #232
                Welcome to the forum Vaughan.
                Now your on 4.3E but what was the version originally?
                Nintendo fitted DVD drives on later maybe 4.1+ that won't play burnt discs obviously they where loosing money. Run sysCheck beta 11 and read the report as shown in that link. If it says The drive supports DVDs then you might be able to play burnt games through NeoGamma R8 or R9 which you can find on here.
                There is also a site where you can type in your Wii serial number and it will tell you when and where it was made for Wii Drive Chip Databse
                Now your softmodded your Wii I hope the first thing you did was the NAND backup thats a must, if you didn't let me know before you do anything else. You also need to install PriiLoader to block online and disc updates.
                You shouldn't get a black screen with MMM thats basically used to install IOS and cIOS wads.
                Now I don't know why you really want to play burnt games as that means you need to buy quality DVD's to burn them (you will need to store these hundreds of DVD's somewhere) your better of buying a large mains powered external HDD and play all you games of that.
                You you use an external HDD then you need to install cIOS245 to cIOS251 for the USB Loaders to work.
                Any problems the please start a new thread save tagging on to an old one?
                Keith
                2010 Golf GTD (170)
                • vaugloo
                  • Dec 2011
                  #233
                  Hmm - Sounds like I am missing a few aspects here
                  Many thanks for reply -
                  Haven't made a NAND back-up or prii loader
                  Wii has been previously soft modded when it was under 4.1 & 4.2.
                  Will look on threads to see how I can make a back up etc
                  Seen a separate trucha bug zip file which may allow me to findf a way around error -1035 on IOS236. I am following James Dean's 4.3 update with Indiana Jones original adventures.
                  Man this is complicated - Hindered by the fact that my two girls keep saying is it done yet? I am starting to think about taking a long drive...... Patience is not one of my strong points (just ask the wife - also foot hole in cheap cardboard kitchen door - yep new house)
                  Oh well - these things are sent to try us
                  • ck-ok
                    • 2592
                    #234
                    just remod it with http://www.digital-kaos.co.uk/forums...indows-170234/ it will give you a bang uptodate mod and save you time messing around try to get different thins working.select the option for a virgin install answer a few questions and away you go.
                    • Keithuk
                      • 2264
                      #235
                      Well the NAND Backup is the first thing you must do before you install any wads as I've said. Now I've have given instruction on how to do this but the search facility on here leaves much to be desired.
                      What your going to have to do is run the softmod install again. You will be shown 3 options if you remember.
                      1. Install Homebrew - which you have already.
                      2. Install BootMii on IOS - which I assume you have done, if not do this again.
                      3. Prepare SD card - this makes a [bootmi] folder on the SD card so you can do the NAND backup. Now this part everyone misses.
                      Check your SD card if you don't have the [bootmi] folder on the root you need to run 3. Prepare SD card. Run HBC from you Wii menu if you don't have any apps in the app folder on the SD card you won't see anything only the bubbles screen. If you do then just exit HBC with the Home button and choose Launch BootMii.
                      Now the remote doesn't work in this part so you have to navigate with the Power button to the gears icon on the right. Then press the Reset button then Reset again to backup your NAND and wait until this is completed.
                      A video if your not sure [ame="http://www.youtube.com/watch?v=m_nihgpiIHg"]How to Soft-mod your 4.3u Wii Tutorial Step 2- Back-up Nand and Installing Priiloader - YouTube[/ame]
                      After this is done and you navigate back to the Wii menu remove the SD card and put it into your computer. Copy the [bootmii] folder and the nand.bin and keys.bin files of the root of the SD card and store them somewhere safe as these will be needed to restore the NAND if you ever brick the Wii. The video shows you how to install PriiLoader as well.
                      There is Digital Kaos - Downloads - priiloader v0.7 in the download section.
                      Keith
                      2010 Golf GTD (170)
                      • Keithuk
                        • 2264
                        #236
                        I've just seen someone reading http://www.digital-kaos.co.uk/forums...loader-109168/
                        Keith
                        2010 Golf GTD (170)
                        • pengi23
                          • Jan 2012
                          will smash bros brawl work only on 4.3U. I am running 4.3E what game do i need in order to get homebrew channel?
                          • ck-ok
                            • 2592
                            #238
                            no need for game anymore read the first page
                            • rrter123
                              • Jan 2012
                              • 4
                              #239
                              I've installed HBC, BootMii. Did a backup, installed wad's and priiloader and changed the options in it, but it still doesn't want to read the DVD's. I'm a total and complete noob, so please go easy on me.
                              • ck-ok
                                • 2592
                                #240
                                how old is your wii? if it was made in around the last couple of years it may not be able to play dvd backups.
                                what dvds are you using and what burning program?
                                try checking your serial number here http://www.wiidrives.com/list
