4.3 mod
  • mercury5
    • Feb 2012
    • 32
    #256
    Hi All. I need help please for WII 4.3E Mod
    • mercury5
      • Feb 2012
      • 32
      #257
      While Clicking on the Stagerring....my WII 4.3E freeze & don't read my SD at all
      • Keithuk
        • 2264
        #258
        What is Stagerring your clicking on, more info needed?
        Which tutorial did you follow?
        Keith
        2010 Golf GTD (170)
        • mercury5
          • Feb 2012
          • 32
          #259
          Wii 4.3E
          Hi friend...I'm trying to softmob my Wii 4.3E. I've been through the tutorials. I am still facing problem!!
          While I deleted the saved game (Lego I. Jones) - when I click on SD (WII) nothing can be found so called PWNS. For info my SD Card is a 4Gb.
          I copied the PWNS which I downloaded to the SD - I performed as it should be. OK... While I enter the Art Room,
          I click on the stagerring etc...???? Now the problem ARISE
          My WII console os freezed completely, mentioning SD Card Not Detected.... and the last line reads...HANGING..
          Respected brother, kindly help so that I can solve that problem
          Thank you loads.
          • mercury5
            • Feb 2012
            • 32
            #260
            Wii 4.3E Softmod
            1. When I am in the Artroom, the left character on the podium, it's the two silhouettes stagerred with an arrow pointing between them.
            2. Tutorial from- Wii softmod 4.3 - Read Me
            • Keithuk
              • 2264
              #261
              Well if you copied the Indiana Pwns to the SD card correctly then you click on Wii Options bottom left. Then Data Management then Save Data then Wii. Then you click on the SD Card tab and select the Wii version your using and copy to the Wii.
              Then when you run Lego Indiana Jones you load the saved game. Then go to the room with the carousel and as you've said.
              Without this saved game the softmod won't start.
              By the way if you softmodding a 4.3 then the easiest way is using LetterBomb.
              I have a friend thats come to visit for the weekend and I softmodded hers a few months ago with Indiana Pwns. She has brought up her next door neighbours black 4.2E Wii for a softmod. I enabled the WiFi connection and updated it to 4.3E and I've just softmodded it with LetterBomb. It takes about 20 minutes by the time I had done the NAND backup which tales the longest time.
              I just got to get the USB Loader GX installed and setup now.
              Keith
              2010 Golf GTD (170)
              • mercury5
                • Feb 2012
                • 32
                #262
                I've just tried one more time....it shows code error 004
                • mercury5
                  • Feb 2012
                  • 32
                  #263
                  By the way...many thanks for the info Keith. Don't think I can mod with letterbomb here in MRU, if you've any alternate options please share.
                  My Wii ver is Black 4.3E
                  Thank you.
                  • happy_highlander
                    • 3535
                    #264
                    Thank you.
                    You can use letterbomb. If you are really struggling go to the downloads section and download modmii run it on the pc and let it update. Follow the instructions and you will be successful
                    • Keithuk
                      • 2264
                      #265
                      I'm very sorry I forgot to mension. To softmod a Wii you need a 2GB SD card not SDHC which version 4.0+ can use thats probably why it can't read the SD card. After its softmodded you can use a 4GB SDHC card.
                      It must be formatted FAT32 and 32bit clusters. Now I've never had a problem formatting the SD card with Windows. Some people have and they have to use a special formater that Digital Kaos - Downloads - sd card formatter
                      Update: I softmodded my friends black now 4.3E Wii and installed all 3 USB Loaders and updated those and everything works so she will be happy. I formatted my 2GB SD card in Windows and it worked perfectly as it does everytime.
                      Keith
                      2010 Golf GTD (170)
                      • jamobex
                        • Feb 2012
                        #266
                        Definitely, the ModMii is the way to go for the poor confused hacker virgins like me. It just did it all and the final guide is an extra godsend that I could sit infront of the Wii with and tick off as I went.
                        Keith, your consistent patience and advice is invaluable! Thank you, thank you, thank you!
                        • Keithuk
                          • 2264
                          #267
                          Thank you for saying, you can click one of the Thanks boxes under what I've told you?
                          Keith
                          2010 Golf GTD (170)
                          • parley
                            • 106
                            #268
                            hi after softmodding many wii's on various firmwares, the last two i have done, i have just updated the wii to 4.3 and used letterbomb, but they have had problems on them , one won't play back ups and the other won't play originals, i have not got them back yet to check why, it prob is because kids have effed them up, but has anyone else experienced any problems similair using letterbomb, and in your experiences is modmi a better option? thanks for your patience reading this.
                            • Keithuk
                              • 2264
                              #269
                              I've had no problem softmodding a 4.3 with LetterBomb I did one last weekend.
                              I don't see why you can't play original discs after softmodding? If it was softmodded in the correct order I can't see how the kids could have effed it up.
                              To play backup games with NeoGamma you need a Wii with a suitable DVD drive fitted as the newer ones 2009+ won't. Other than that you play backup games with the USB Loaders after you install the original disc to the HDD.
                              ModMii is a good option to try. I've only used ModMii to update any wads using the sysCheck.csv.
                              Keith
                              2010 Golf GTD (170)
                              • parley
                                • 106
                                #270
                                thanks for the reply i tested it with 3 back up discs and all was well, first time ive had any problems i will update when i get the wii back.
