modmii 4.3.4 for windows
  • Qwertzycoatl
    • Jan 2012
    • 8
    #136
    Originally posted by Keithuk
    How has she knackered the R4 chip?
    Do the online 4.3 update then you can use LetterBomb which will softmod only then you need to sort out your USB Loaders.
    Oh Excellent thanks, I was just reading the letterbomb page when you posted this.
    R4 has just stopped being recognised.
    Stripped it down and cleaned the contacts a bit (just using an earbud, no chemicals) screwed it all back up and nothing.... shame just got her a couple of good things.
    So I basically do an online update to 4.3 then letterbomb?
    The loaders I assume are the ones available on the main page?
    Thanks for all your help, the last wii I had was 1 week after release date and was hardware modded
    • Keithuk
      • 2264
      #137
      Yes LetterBomb will only softmod the same as Hackmii does. Now the LetterBomb site doesn't give you alot of instructions but the LetterBomb.zip txt files do. Now I haven't used LetterBomb but with the older Hackmii 1.0.8 you had 3 options to install.
      1. Homebrew - softmod
      2. BootMii on IOS with 4.3
      3. Prepare SD card - this write the [bootmii] folder on the SD card so you can do the NAND backup which is the very first job you must do after softmodding.
      In README-Bootmii.txt it says how to do a NAND Backup/Restore but the instructions are limited. I have talked about this last week http://www.digital-kaos.co.uk/forums...ml#post1391963
      Then you need to install PriiLoader 0.7 on the same page.
      Then you need to sort out the USB Loader there are tutorials on here. There are 3 main USB Loaders but the best one is USB Loader GX in my opinion.
      Then you will need a large external hard drive preferably a mains powered one to add all your games onto.
      I went onto the LetterBomb site before Christmas so I could download the LetterBomb.zip to see what files were in there. I entered my MAC number and downloaded the zip file.
      I looked on my Wii for the LetterBomb message but it never came.
      Keith
      2010 Golf GTD (170)
      • Qwertzycoatl
        • Jan 2012
        • 8
        #138
        Excellent, thank you very much.
        I've gotten up to the priiLoader install but don't seem to be able to get any further. The SD card never seems to be recongised as having anything on it.
        What should I have on the SD card once the homebrew is installed please and where do I get all the files? 4.3 mod references WADS but the files are not marked (as far as a n00b can tell anyway)
        Any help greatly appreciated.
        • ck-ok
          • 2592
          #139
          are you using modmii or another tut?
          • Qwertzycoatl
            • Jan 2012
            • 8
            #140
            I've used letterbox to get homebrew so far as recommended.
            If I try and install PriiLoader now I get errors stating something about CIOS....
            Just fails sadly and won't go any further.
            If I do a standard option to install it gets root etc then fails.
            Also don't seem to be able to get MMM to actually appear and load
            • ck-ok
              • 2592
              #141
              if i dont know what tutorial your following i cant help
              • Qwertzycoatl
                • Jan 2012
                • 8
                #142
                That one is the one I am following after using letterbox.
                Thanks for any help you can offer
                • ck-ok
                  • 2592
                  #143
                  have you followed the first page of this thread http://www.digital-kaos.co.uk/forums...-3-mod-157379/ ?
                  • Qwertzycoatl
                    • Jan 2012
                    • 8
                    #144
                    I have yes...
                    At this point:
                    Multi-Mod Manager Starts (via cboot2)
                    It doesn't... nothing happens just bootmii starts so sadly:
                    Never Uninstall IOS, you will brick your wii
                    Select "WAD Manager" - Press A
                    Press (1) to "Install all Wads" - Press A
                    19 wads should install without issue
                    "Press any button to continue"
                    Be sure all the wads install, very important
                    If the wads fail to install, install 1 at a time
                    Press B two times- main menu
                    Is all impossible to reach. Is there something obvious I have done wrong here?
                    • ck-ok
                      • 2592
                      #145
                      I have yes...
                      At this point:
                      have you extracted all the modpack onto the sd card?
                      have you done the nand backup?
                      • Qwertzycoatl
                        • Jan 2012
                        • 8
                        #146
                        Nand backup done.
                        Found that MMM was not in the modpack for some reason. DL it and put it in the apps folder so at least it loads (moral victory for a n00b there )
                        Tried doing the batch install of all 19 WAD files and all failed, tried them 1 at a time and they all failed.
                        I have a hideous feeling I have missed something stupidly obvious here
                        • ck-ok
                          • 2592
                          #147
                          Nand backup done.
                          re-download the modpack copy nand backup and keys to computer format sd card extract modpack to sd card and try installing wads again
                          • Qwertzycoatl
                            • Jan 2012
                            • 8
                            #148
                            Ok thanks
                            Will try that now.
                            • Keithuk
                              • 2264
                              #149
                              Well I forgot to mension in my other post you need a 2GB SD card to softmod even though 4.0+ Wii's will take a 32GB SDHC card.
                              You may notice at the top of the PriiLoader screen is says something link uses IOS58 did you install that with MMM first?
                              If MMM doesn't load then download it again, just extract the MMM folder out of Digital Kaos - Downloads - Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4
                              Does PriiLoader install at all? It will show can't find password file but you ignore that.
                              Put sysCheck in the apps folder on the SD card and post the report.
                              Keith
                              2010 Golf GTD (170)
                              • hayseed
                                • Jan 2012
                                #150
                                saweet
                                Thanks for Modwii!
