modmii 4.3.4 for windows
  • Keithuk
    • 2264
    #91
    Originally posted by kc57
    I updated HackMII and HBC to the latest versions and now it won't run the games from my USB HDD as it did before the update.
    Why did you update HackMII which is HBC if it was working ok?
    You can get the latest Homebrew here thats the one I used.
    Which USB Loader did you use and did you have to re wad anything?
    Keith
    2010 Golf GTD (170)
    • CloverLawn
      • Jun 2011
      #92
      going to give it a go...
      ill cross my fingers, because im new on this, but I just move to the UK and im not going to pay for a whole new wii...
      • Keithuk
        • 2264
        #93
        So where have you moved from CloverLawn, which version of Wii did you use before or have you brought that with you?
        Keith
        2010 Golf GTD (170)
        • Keithuk
          • 2264
          #94
          Welcome to the forum.
          Originally posted by CakeEater
          Fingers crossed, don't brick on me.
          You won't brick it providing you install Homebrew then install BootMii then Prepare the SD card (must be a 2GB SD card), then from Homebrew have Priiloader in the apps folder on the SD card and install that.
          After you have done that you should be able to run BootMii from Priiloader is you press the Reset button and select BootMii then use the Power button to navigate to the arrow button on the right then press Reset. Then press Reset again to copy your NAND to the SD card.
          You need to put your SD card in a computer and copy the bootmii folder and keys.bin and nand.bin of the SD root to somewhere very safe as you will needs these files to un-brick your Wii should it happen.
          I've never seen a bricked Wii but if everything is unusable then you won't access anything. You press the Rest button then power it up to run Priiloader then select BootMii.
          Keith
          2010 Golf GTD (170)
          • happy_highlander
            • 3535
            #95
            Bricking a wii is rare nowadays as long as you follow all the instruction
            • poseruk
              • Jun 2011
              tried many ways
              I have tried many different ways of modding my wii. I have set up my sd card with the files but when it says I should get a message saying " load boot.dol" all I get is the directory contents.
              any offers of help ?
              • pardinha
                • Jul 2011
                Does this work with sdhc cards???
                • Keithuk
                  • 2264
                  #98
                  No, even though v4.0 and above are setup to use SDHC cards up to 32GB its HBC that doesn't recongnise them.
                  I softmodded my friends a couple of weeks ago and I put HBC on his 4GB SDHC card. I copied the save game of the SD card to the Wii no problem and ran LEGO Indiana Jones but when it searched for info on the SD card it couldn't find it. I went home and fetched my 2GB SD card and put the same files on it and it worked perfectly.
                  Once HBC is up and running you can use an SDHC card?
                  Keith
                  2010 Golf GTD (170)
                  • Keithuk
                    • 2264
                    #99
                    Originally posted by rvschie
                    I.ve tried several downloads for version 4.3E. Nothing worked so far. Hopefully this one will.
                    Downloads like what?
                    I've downloaded 46 games and they all work.
                    Keith
                    2010 Golf GTD (170)
                    • rs18000
                      • Jul 2011
                      Thanks for this, im gonna give it a try now
                      edit
                      all done now and was perfect and easy, thanks
                      just follow the instructions
                      • jetpen
                        • Jul 2011
                        Hi folks,
                        Just joined the site, seems like the right place for me!
                        Had a Wii for about 4yrs, got a Wiikey shortly after the kids trashed a disc and been running back ups since.
                        Until recently that is, when they all stopped working. Originals are fine so I presumed, 4 yrs on, I could trust them with the originals. Didn't take long for them to prove me wrong despite warning them to take care of the discs!!
                        Just need to find a suitable SD card and a little time now.
                        Cheers and thanks in advance.
                        • Jarppa
                          • Jul 2011
                          So can you softmod you 4.3E with this without using any game exploits? (AKA Indiana PWNS or Bat Haxx)
                          • Keithuk
                            • 2264
                            #103
                            No on 4.3 you can't.
                            Keith
                            2010 Golf GTD (170)
                            • richin1995
                              • Jul 2011
                              Is there any other way to softmod a 4.3E wii?
                              • Keithuk
                                • 2264
                                #105
                                Not that I know of else I would have said?
                                Keith
                                2010 Golf GTD (170)
