modmii 4.3.4 for windows
Welcome to DK.
You don't need a game to softmod a 4.3 Wii anymore just use LetterBomb which ModMii tells you to use.Keith
2010 Golf GTD (170)Comment
no problems for the harddrive
just do the softmod again but now you are on 4.3 you gonna have to use the lettrbomb to get the homebrew channel back on your wii or try modmiiComment
Welcome to DK poolprop.
If you didn't have a NAND backup before then you may as well redo the softmod with LetterBomb but this time install PriiLoader 0.7 so it won't do anymore updates as you can block disc and online updates.
If USB Loader GX used to work ok before then install d2x v.7.0 Final with MMM.Keith
Skylander Consern
Hi There BirdT, can you tell me what problem with Skylander you had, and if using modmii 4.3.4 installer solved your problem?
Are you still able to play and use skylanders Portal of power within a backup of the game?
I am trying to find answers to be sure I don't brick my 7 year old son's Wii, he worked so hard to save money to actualy buy this game, I hate to brake his hart telling him he can't use his game anymore because daddy played around on the Wii.Comment
this program works greatHi There BirdT, can you tell me what problem with Skylander you had, and if using modmii 4.3.4 installer solved your problem?
the chance of bricking a wii is just about nil using this program just follow the tutorial it writes for you and you will be fine.sigpicComment
