modmii 4.3.4 for windows
  • Thrashbast
    • Feb 2012
    Does this system work for Zelda Skyward Sword over USB
    • Keithuk
      • 2264
      #167
      Yes The Legend of Zelda Skyward Sword - PAL - SOUP01 works on my system without any tricks\cracks.
      Keith
      2010 Golf GTD (170)
      • atw1973
        • Feb 2012
        Hope this helps
        I have tried at least half a dozen "tutorials" and have yet to have one that works on a 4.2e
        I keep trying to use a Loader GFX and it says I need cIos 222 i have tried 5.1 installer to update to 222 but it locks up... any ideas?
        • Keithuk
          • 2264
          #169
          Well I don't know whats that different with 4.2E but USB Loader GX and the other two use cIOS249 by default or cIOS222, cIOS250. I've said before I wouldn't bother with Uloader 5.1.
          Which tutorials have you been following?
          Keith
          2010 Golf GTD (170)
          • hink
            • Feb 2012
            #170
            Right, I have followed the modmii tut to the tee. I have USB Loader channel, I have used WiiBackupManager to format the drive (I am using a 16gb Sandisk Cruzer Slice) in WBFS and to transfer a Wii back up game (007 Goldeneye). When I point and click on the channel page, USB Loader says 'Please connect a USB drive'. If I click on start it shows a splash page for a split second and resets. Any Ideas? Also as a noob is there a Glossery for all the WAD's, cIOS's, IOS's? If I had an idea what they did It'd be a start!!
            • ck-ok
              • 2592
              #171
              make sure that you have the drive in the correct port if its lying down its the bottom one.
              try using Digital Kaos - Downloads - wbfs manager 3 to format the drive and to load your isos
              • happy2help
                • Jan 2012
                • 6
                #172
                I have playing with loads of drives over the weekend - mostly with no luck, various USB controllers.
                You need to remember to make the partition active and have the 2 folders ("apps" and "usb-loader") on the drive.
                • hink
                  • Feb 2012
                  #173
                  Thanks guys. So just a sanity check. The USB drive has to have 2 x partitions, one FAT32 partition to house the usb-loader and wbfs folders and another WBFS partition to house the game image? I have just been formatting the USB drive in WBFS and using WiiBackupManager to put the game image on.
                  • happy2help
                    • Jan 2012
                    • 6
                    #174
                    Just format the whole thing as FAT32 and WiiBackupManager will put the images in the WBFS folder
                    • happy_highlander
                      • 3535
                      #175
                      Not really if it is a small drive format it all to fat 32 wii backup manager will create a wbfs folder on the drive to house the games and usb loader gx is happy to read from a fat 32 drive, but remember your gx folder must be inside your apps folder on the drive
                      • cambi23
                        • Feb 2012
                        #176
                        will try this out,is it just as easy as it sounds let the modmii do all the work,plug in the flash drive to my wii and done.
                        • happy_highlander
                          • 3535
                          #177
                          Almost that simple, just read and follow the instructions to the letter but you need to use a maximum size of 2gb sd (not sdhc) card for the install it cannot be done via usb flash drive
                          • cambi23
                            • Feb 2012
                            #178
                            thanks for that mate,cant seem to find the instructions once iv opened the rar file or do i have to load the modmii exe then it gives me instructions,have not loaded it yet as dont have my wii at the moment,one more thing is it ok to use a card reader to copy the files onto the sd card as my pc does not have a sd card slot so only way for me to get them on the sd is by adapter will that be ok.
                            cheers
                            craig
                            • Keithuk
                              • 2264
                              #179
                              Welcome to the forum Craig.
                              The instruction are built into ModMii.
                              Yes a card reader is fine thats what I use on my old laptop and desktop.
                              Keith
                              2010 Golf GTD (170)
                              • tanyaimp
                                • Feb 2012
                                Will it work on 4.3e?
