As keith says iso's are 4.37 gb but the way it works is that when you add games to your fat 32 drive using wiibackup manager (wbfs manager cannot add games to fat 32 drive) it will automatically convert games to wbfs which as keith says is much less than iso (this depends on game content as they are all different sizes once converted) so the only time you will have a file over 4 gb is with a dual later game which wiibackup manager will split into two files but during playback of any dual layer game the transition from one file to the other is seamless so you will never notice it.....Which in laymens terms means the file size limit on a fat 32 drive isn't an issue
modmii 4.3.4 for windows
I don't like Wii Backup Manager just to convert games as the help it totally crap. I just want to convert files not add them to a drive.
I always use WiiGameConverter_GXS its simple like me.Keith
2010 Golf GTD (170)Comment
Welcome to DK.
About 30 minutes if you use ModMii with the SU option from a sysCheck.
You can also read http://www.digital-kaos.co.uk/forums...-250-a-291481/Keith
Hi All,
I used a complete4 and other method to hack my wii some time ago but most recently some games i have dl dont work, will this 4.3.4 mod work any better than my current 4.3e (i think)Comment
Bought Skylanders Giants, pressed start button blue screen error 002 is this cured with priiloader or something else. My sons Wii has Homebrew, Wiiflow and USB Loader GX. Could I remove Homebrew and avoid installing anything else as mentioned previously? What is my best option to avoid this in the future? Thanks for any and all advice.Comment
Welcome to DK.
You first need to post a sysCheck as instructed in that link so we can see your system wads.Keith
Skylanders Giants is a special game that needs a special controller which you buy in the package not a USB Loader.Bought Skylanders Giants, pressed start button blue screen error 002 is this cured with priiloader or something else. My sons Wii has Homebrew, Wiiflow and USB Loader GX. Could I remove Homebrew and avoid installing anything else as mentioned previously? What is my best option to avoid this in the future? Thanks for any and all advice.Keith
Here is my system check;
sysCheck v2.1.0b18 by Double_A and R2-D2199
...runs on IOS36 (rev 65535).
Region: NTSC-U
System Menu 4.2U (v481)
Priiloader installed
Could not detect the drive date!
Homebrew Channel 1.0.1 running on IOS61
Hollywood v0x21
Console ID: 124275818
Boot2 v4
Found 79 titles.
Found 45 IOS on this console. 6 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 65535): Trucha Bug
IOS10 (rev 768): Stub
IOS11 (rev 65535): Trucha Bug
IOS12 (rev 65535): Trucha Bug
IOS13 (rev 65535): Trucha Bug
IOS14 (rev 65535): Trucha Bug
IOS15 (rev 65535): Trucha Bug
IOS16 (rev 512): Stub
IOS17 (rev 65535): Trucha Bug
IOS20 (rev 65535): Trucha Bug
IOS21 (rev 65535): Trucha Bug
IOS22 (rev 65535): Trucha Bug
IOS28 (rev 65535): Trucha Bug
IOS30 (rev 65535): Trucha Bug
IOS31 (rev 65535): Trucha Bug
IOS33 (rev 65535): Trucha Bug
IOS34 (rev 65535): Trucha Bug
IOS35 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 65535): Trucha Bug, NAND Access
IOS38 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS40 (rev 65535): Trucha Bug
IOS41 (rev 65535): Trucha Bug
IOS43 (rev 65535): Trucha Bug
IOS45 (rev 65535): Trucha Bug
IOS46 (rev 65535): Trucha Bug
IOS50 (rev 65535): Trucha Bug
IOS51 (rev 4864): Stub
IOS52 (rev 65535): Trucha Bug
IOS53 (rev 65535): Trucha Bug
IOS55 (rev 65535): Trucha Bug
IOS56 (rev 5146): Trucha Bug
IOS57 (rev 5661): No Patches
IOS60 (rev 65535): Trucha Bug
IOS61 (rev 5405): No Patches
IOS70 (rev 65535): Trucha Bug
IOS201 (rev 3094): Trucha Bug, ES Identify, NAND Access
IOS202[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS249[38] (rev 14): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS250 (rev 65535): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS254 (rev 260): Stub
BC v6
MIOS v10
Report generated on 2012/12/25.
I have no idea about any of this, I'm doing this on behalf of my son. Just want the disc or the USB version to play normally with the portal working normally. Thanks all and Merry Christmas!!!Comment
I downloaaded Skylanders Giants and it won't work without the portal that comes with the game package.
I've never seen a sysCheck with all those many Trucha Bug wads. It an old sysCheck because Homebrew is running on IOS61.
Because you have the sysCheck.csv from the sysCheck which is on the root of the CD card. Download ModMii 2.3 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv. Its easier to put this on the root of a drive as it saves typo's.
That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
First of run IOS236 Installer from Homebrew and install IOS36 as IOS236. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there. Watch for the Installed OK message after each one. If any don't install just try them again.
Now ModMii only installs 2 d2x v8.0 wads so you may as well install all the others. d2x v8 Final wad pack
Then post a new sysCheck.Keith
Hi, I need to upgrade from 4.0E to 4.3E. Can anyone help?
Thanks alot!
Ok, I found this thread: http://www.digital-kaos.co.uk/forums...e-4-3e-291714/
Followed Happy_Highlanders instructions and now my Wii is upgraded to 4.3.
So thanks to the forum and especially to HH.Last edited by cng; 1 January, 2013, 17:10.Comment
