Epson SX125 waste ink counter reset
  • Willekille
    How is it on win7 sx130?
    Is it working?
    • maneken25
      is there any downside of software if other tints are full and only black compatible tint isnt recognised?
      • Canker_Canison
        • 3904
        #138
        This software should only be used if the waste ink pads are full.
        Attempting any other repairs with this software could damage your printer beyond repair.
        If your printer doesn't recognize one or more ink cartridges, you need to clean the IC chip on the cartridge or change the ink.
        Canker
        [COLOR=Green]
        • juraj1986
          Hi, hope it works, I just cleaned my epson head (clogged pretty bad) an inks are making a problem, why is that, maybe because the printer doesn't apply non original ink tanks???
          • Gangstermn
            Is there software for SX610FW model?
            • trevice
              I hate that Epson us to use these programs to properly use their printers.
              • DamianGto
                I hope this will work.
                My biggest mistake was to buy the sx130 printer.
                I use to have HP and it is very easy to refill and they last much much longer.
                • giedrim
                  is this sofware compatable with Epson L100?
                  • Canker_Canison
                    • 3904
                    #144
                    New thread created with reset tool
                    Canker
                    [COLOR=Green]
                    • feghio
                      #145
                      Hello, I followed the procedure and the printer worked again, but damn, after 3 prints, stopped again giving the same problem as before. I repeated the procedure again and again started to work. but my question is: Is there a way to prevent the printer hangs forever, and thus I am forced to repeat the same procedure?
                      thank you very much
                      • KrockOss
                        Does it work for SX130 ?
                        • topjazz
                          #147
                          reset epson stylus sx130
                          Hello,
                          I just bought 1 original epson cartridge (yellow), and replaced it.
                          After replacing it, all cartridges are disabled.
                          I must say in the past i used also compatible cartridges.
                          I've tried everything (power off for a while, desconect from pc, etc...), nothing helps...
                          I hope the epson sx125 waste ink counter tool will help...
                          Greetings,
                          topjazz
                          • gallone
                            hello fdhgdfhgd
                            • qgerce
                              Resetter
                              Hi, it's a great software! Thanks!
                              • Zouhair
                                i had the same problem with my epson sx 130 , i hope that it can help
