Huawei E5830, E5832 & E5838 Free Unlock
  • andycast
    • 28
    #481
    Great tutorial, finally managed to unlock my e5030, I need advice on what to do next, can I install any network sim and it should work? Also will I need to flash new firmware to install a generic dashboard/ui for universal network tethered use?, great work, thanks in advance.
    • Lisac13
      • Dec 2013
      • 5
      #482
      I got the Huawei e5223 but I need an unlock code for it. I can't do the tutorial at the start as I use it for my phone. It is a hotshot wireless device. Any help would be greatly appreciated and would save me from having to buy a diff one. Thanks in advance. Lisa.
      • Jim.Mahoney
        • Feb 2010
        • 4249
        #483
        Are you sure this isn't a E5332? Any way, if it's post 2012 then you can't read the codes...
        • Lisac13
          • Dec 2013
          • 5
          #484
          Oh it is actually, sorry I'm dyslexic, all always put things in the wrong order
          • Lisac13
            • Dec 2013
            • 5
            #485
            So is the only way to get it unlocked to get it from o2 after spending the credit?
            • Jim.Mahoney
              • Feb 2010
              • 4249
              #486
              I have used these people who charge ?3.99 per code.
              Just make sure that when you pop in the wrong SIM that it actually asks you for the unlock code.
              If it does, then go to Huawei Unlock by IMEI and fill in the model number and IMEI.
              They do the codes manually but it is usually within 12 hours or so.
              • Lisac13
                • Dec 2013
                • 5
                #487
                Jim. Thank you so much. I'll will give them a go and I appreciate you taking the time to help me. Happy Christmas. Lisa.
                • Lisac13
                  • Dec 2013
                  • 5
                  #488
                  Code worked perfectly, thanks for processing it so quickly Jim. And you were very reasonable, only?3.99. I have recommended you others already.
                  • pyka312
                    • Mar 2014
                    Unlocking and flashing E 5832 S with a firmware that let me change APN:
                    1. I used QCMobile****ysisToolV5.06 for reading EFS
                    2. I found the unlock code with ExtractText, form me was the first code from the column
                    3. I could't enter the code using CardLock_Unlock because didn't detect my modem.
                    4. I decided to enter the code using the web interface. WORKED PERFECTLY.
                    5. I flashed my device with this firmware WLE5832S3095001_ALL_VERSION_V100R001C365B311_USB
                    from here: https://mega.co.nz/#!bwxC2KyJ!M4TtCR...44P0phtuDor26o
                    6. Here is the forum where I found the firmware HUAWEI E5832s cant repair - GSM-Forum
                    I'm from Romania and I tested my device with 3 different networks: RDS, ORANGE , VODAFONE
                    • Frogger
                      • Oct 2012
                      • 422
                      #490
                      I need to know if theres an unlock code for a 3 Network Huawei E585 or could someone post the latest DC unlocker client for doing this?
                      Thanks In Advance
                      IEMI 352398043386186
                      • Canker_Canison
                        • 3904
                        #491
                        Thanks In Advance
                        I don't have support for this modem. But I do have support for the E585u-82 & E585v2, both produce the same code.
                        Try it if you wish....
                        Code : 31031037
                        Canker
                        [COLOR=Green]
                        • Brodi
                          • Jul 2014
                          e5832 NetCom WLC1GCPU
                          Please unlock code.
                          imei 354104030758280
                          • duewKneeds
                            • Oct 2017
                            • 6
                            #493
                            Huawei E5830 E5832 E5838 Free Unlock
                            Just wondering if this hack still works and is current??I'm pretty sure I have a Huawei E220 on "3 UK Network" somewhere and would like to use it if I can get free internet on the moveWould appreciate someone confirming
                            • abkuf
                              • Sep 2018
                              need help unlocking my huawei E5830s
                              I extracted the efs but was unable to udentify the 8 digits passcode
                              It would be very appreciated if u can help me
                              thank u
